Who makes this slave cylinder?
Slave has a leak in it. So I bought one of these
But it has one of these.
The mechanic told me that the clutch is huge and obviously not stock. So I need to replace this slave with a new one like it, cause I dint want to go back to a stock system now that it has an upgraded one.
Thanks for the help in advance.
if youre reffering to the first pic,, it looks like an ls7 slave to me
you have to see what clutch is in the car in order to determine which slave will work with it
I have the mcleod unit and I am EXTREMELY dissappointed, nothing but trouble and I currently have to pull the transmission to deal with more issues caused by this unit. what issues were you having? I had a ls7 unit prior to the mcleod and my pedal went from a mild stock like feel to a full out race car. The pedal is way too strong and it drives me nuts if I run into traffic. I talked to the lead designer for mcleod at the PRI show and he told me they have had some units with defective bleeder lines (bleeder threads were allowing air in) so if that is the case with yours you can get a free exchange if you send it to them, anyway good luck and keep us updated. Also I didn't notice in the pictures, but do you have a spacer?
As far as the spacer, I am assuming it is still on the car. This is all my mechanic took off. I will be sure to tell him to remove the spacer prior to installing the other slave.
you will need to use a spacer with the ls7 slave as well if I remember correctly. I lose my pedal everyday as well, it was fine for a couple months and now has given me nothing but problems. I find it interesting you also have a unit because they told me they never built one for a 1st gen V when I had mine made (fall 10'). sandman how strong was your pedal? how long have you owned the car? (trying to figure out how old your unit is)
thanks, I was just wondering. serik I know you can "make it work" but I was wondering because I had to send it back to McLeod for adjustments 3 times so I was hoping they didn't do the same to others. Mine was made in August of 2010 so it's not that old, but I would have been surprised to hear there was one older than mine. Anyway I'm glad to hear your pedal wasn't crazy, it gives me hope that if I don't ditch the McLeod I can have it rebuilt/reconfigured to work correctly for our cars. I originally had the unit installed by a shop and have never heard of the pedal going from stock to race with a slave/throw out change, but from what itsslow said it's probably a defective unit. This car keeps eating slaves and I thought shelling out the money for the McLeod would fix it, maybe there's still hope
also where did you get this information? I paid around $550 for the bearing and $150 for the special quick disconnect line I needed. That's another reason I am so frustrated right now, $700 invested and I still have problems. I will probably be mailing my unit back to them tomorrow, so I will keep you updated
Also I am not going with the Leod any more. Going with the LS7 unit. But when I did get it, it was practically screwed all the way down so I am assuming that there really wasnt that much pressure being used.
