Pulled trans...now no speedo
So, my trans was leaking a good bit where the tailhousing met the trans. I pulled it out of the car, and took it down to a local trans shop.
Finally got around to putting it back in, and now the speed doesn't work.
I changed the speed sensor, and still nothing.
The battery was disconnected for about a month.
Is it likely the trans shop screwed something up, or is there something I'm missing?
I bet you can also put the car into reverse at speed because you/they accidentally reverse connected the lockout and speed sensor harnesses.
Switch the wires back and you'll be good to go.
![](http://www.classictiger.com/mustang/T56-sensor-soleniod_locations.jpg)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Yea, how stupid to make the VSS and temp sensors the same connector....
Thanks for the help guys, got it done over the weekend. It's been over a month since I drove the car, I almost forgot how it felt!
