Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
ls9 clutch confusion
Old 05-06-2012, 07:58 PM
  #81
Onefast V's Avatar
Okay clutch is bled.how easy should the ds coupler spin when in gear with the clutch in? In neutral it spins very easy. But in gear with clutch in definitely is more effort.
Old 05-06-2012, 09:43 PM
  #82
heavymetals's Avatar
Should turn freely.
The only drag I noticed is I could hear a slight scrape noise, but that was expected as there is nothing that prevents it.
You can't compare it to neutral as the gears are not spinning.
Use 2nd and compare.
Also it helps to have someone else slowly push on the pedal as you turn the output shaft.
Old 05-06-2012, 09:53 PM
  #83
Onefast V's Avatar
It does turn freely just some effort required so ill keep my fingers crossed as I put it all back together!
Old 05-07-2012, 11:13 PM
  #84
Onefast V's Avatar
All back together. I'm undecided on the result as the shifter is very tough to move in general, i believe this is due to the brass shifter bushing I installed in parallel and it needs to break in.
http://www.thegearbox.org/catalog/it...17/6239116.htm
Old 05-08-2012, 07:13 PM
  #85
Onefast V's Avatar
Final verdict is 90% solved! Only issue is still having difficulty getting into reverse
Old 05-08-2012, 07:36 PM
  #86
RADEoN's Avatar
glad you got it figured out... my slave idea was a shot in the dark :X
Quick Reply: ls9 clutch confusion
