How wide can we go when widening stock V wheels?
I know a few members have done this and I'm considering having a pair widened myself. I'm assuming 10" is the max width in the rear? Anything else need to be done or changed to allow this to work?
I'd like to be able to run a 295/35 comfortably out back and have the wheel fill the wheel well nicely. I want to go as wide as possible without causing any clearance issues.
Thanks in advance fellas!
I considered doing a 5-lug swap myself but I like the look of the stock wheels and don't really wanna mess with all that. A 315 would be nice but anything 295 or wider, I'd be happy.
You'll need 5mm spacers and different trailing arms. I posted a thread in the CF what i did to mine
I think anything more than 10" you'll run into problems, you'd definitely need a bigger spacer, then you would need longer wheel studs (with anything over a 5mm spacer)
Also any further out you'd probably rub the fenders even if rolled, if you are lowered.
I may have even posted a thread here on it too.
315's lowered forget about it.
Sounds like I'll just widen them to 10", run the 5mm spacer and swap trailing arms if needed and stick with a 295/35 or something like that so I can still lower it without any issues.
https://ls1tech.com/forums/cadillac-...ated-pics.html
Also has the link to my CF thread in one of my posts
