Stereo crackling/static/disturbance 2004
Today I get in the car, music starts playing and its got this awful static crackling that comes in and out of all the speakers.
It does it weather its on the radio, playing a cd or dvd.
Reminds of listening to a radio station and losing reception. Its very loud and noticeable.
Anyone had this issue before?
Fixes?
My favorite part and main reason I wanted the car and now its gone all to **** lol
Fixes?
The stereo is really tour favorite part of the car? I hope that is sarcasm. Anyways it sounds like you might have blown a speaker. Does it come from all speakers or just a certain one?
If it is coming from every speaker you can atleast narrow down the source as the deck. I would pull it and look for obvious issues like loose wires and gremlin nests.
Does it change with engine speed? If yes, you have a serious ground loop issue.
-Also check your engine and battery ground straps to make sure they are tight and not corroded.
I've had this happen before, still trying to trace it down. For me it only happens during cold weather.
Also had that one issue where sound completely stopped working. Had to disconnect the main harness from the amp in the rear and reconnect it in order for the sound to come back.
03-08-44-005G IB Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids May Be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) March 9, 2007
06-08-44-020 TSB Audible Pop/Static Noise Heard Through Radio Speakers on AM Radio Band with Brake Apply (Check Body Grounds and Replace Center High Mounted Stop Lamp Assembly, If Necessary) May 30, 2006
There are tons of TSB's these are a couple that could be related
I thought I was crazy having this problem... Apparently it's more common than I thought... I'm thinking in my case it could be the iPod adapter... Mine crackles with just the stereo powered up not necessarily with music playing
Its all speakers. It actually stopped doing it now. It only did for 2 days. I didnt have the rear defrost on at any point so I think it was just the deck screwing around with me.
Where is the amp in the back that you disconnected harness from?
The amp is in the trunk, drivers side I believe. There are other components scattered throughout the car. My sound went out completely, but my head unit functioned as it should. Ended up being a loose fuse, in the box under the back seat.
Thats the exact problem Im having. I will be checking that asap. Was the fuse bad or just loose?
Mine was just loose. I pulled it, inspected it, and re-installed it. I then went further into my "troubleshooting"...never touched another plug/fuse, just inspected connections. When I left, sound was back on.
