New High Flow Cats
Purchasing some new magnaflow high flow cats this weekend, but have a question about the O2 sensors. Should I keep the originals, or spring for new? V1 has only 40k miles on original cats/O2's.
Thoughts?
Thoughts?
It doesn't matter, you're going to have to get the Cat efficiency DTC's turned off after you remove the OE Cat converters anyhow...or the check engine light will turn on.
Probably better off getting tuning pipes than having the converters that do not satisfy the emissions performance criteria anyhow.
Unfortunately, my state requires emissions test, so I have to keep cats on. However, what do you mean by having converters that do not satisfy emissions criteria? Have you had experiences with the magnaflow high flow cats where they were not up to par for emissions tests?
Does your state simply do a visual insp. and rely upon the OBD II software to verify correct operation as most jurisdictions? If your state uses a tail pipe sniffer, you're very likely to fail.
One of the reasons that aftermarket catalytic converters do not satisfy the performance criteria is that a catalytic converter is designed to "store" a specified amount of oxygen, which is directly related to size.
So it would probably be prudent to have the car tuned afterwards and have these codes set to no error.
Pretty sure they do tailpipe and possibly visual...as I have seen some cars get visual done, but always tailpipe.
So I am wondering if it would be worth it to just keep my stockers for the once a year check. 2-3 hours of work once a year never killed anyone...yet!
If you intend to swap the headers out for inspections I would invest in some arp header studs, will make your life ten times easier when you go to swap. Never have to worry about broken bolts in the heads.
I am not sure why go to all of the trouble, when you can have the car tuned and have the rear cats turned off and leave everything installed and not get haseled.
And modern day cats do not "rob" any power per say. Especially High Flow stuff.
Robbing power is of the older type cats.
