Coolant Level Sensor Location
Every time that I turn on my recently acquried V1 Cts-v, I get a message telling me to check the coolant level. I've checked it many times and after seeing that the level hadn't changed any of the times I looked at it, I decided to just keep an eye on my temperatures (which has also stayed in line).
I ran the service history of the vehicle and found out the radiator was replaced twice in it's lifetime. I've also inspected the radiator for leaks and have found nothing. My only remaining idea is to check the actual sensor. Does anyone know where it is located? I searched a few forums and the one thread that addressed the location had broken picture links.
Thanks in advance.
Thanks in advance.
I haven't gone investigating it yet, but just to follow up on what FoD said, my coolant level is at the full mark. So between that and the fact that it isn't losing anything, I have to imagine that the sensor is toast.
It's on the reservoir. Only way to access the sensor is by removing the reservoir. It's not hard at all to do so. I think all I did was take the driver side wiper off. Removed the cowl trim. unbolt the master cylinder from the booster and move it aside. Fairly simple. Took me like 25-30 min to replace my reservoir.
