Finally got a quick dyno pull
Makes a whole lot of sense once you think in terms of airflow.
Down low, where torque peaks, the blower is not maxed out on airflow, however up high in the RPM range, the engine requires a lot more flow and at that point, it's beyond the Maggies ability to flow.
try porting it? why spend all that money on another blower when your spraying it anyway?
1 Post
Makes sense that some FI setups make more TQ then HP.
Either way, looks good. Going to have to figure out how to keep that running cooler so you aren't losing all that power to heat soak.
98 cobra, as far as porting; no one wants to touch it due to it being a maggie case...they say its already hogged out pretty good.
