high flow cats and plug defoulers
I'm looking to buy a set of spark plug defoulers to use with a set of Magnaflow high flow cats. Curious as to what other's have used who were successful in preventing a CEL from popping up.
I see a lot of the standard shaped, short length versions
![](http://ecx.images-amazon.com/images/I/21sYoUdr6nL.jpg)
Wondering if a 90* version might offer better results allowing the O2 sensor to be pulled further from the exhaust stream.
![](http://ecx.images-amazon.com/images/I/3146MhDYVUL.jpg)
Did that many years ago with an 01 C1500 truck I swapped 4.8 for a 6.0 with headers and duals. Got them off the "help" sec in the local auto parts store. Main thing I remember is that had to use 2 for each sensor, drill 1 so the O2 would fit in it, and the screw both into the 2nd, then screw all three in the pipe. Not exactly the right way, and having them turned off would be better, but kept my CEL out.
