so...I need 1 more inch!!!
It's lowered on H&R springs right now, and I just need 1 more inch (don't we all! ) to tuck the top of the tire.
I have the cradle down right now, since I'm doing upper control arm and trailing arm bushings.
Has anyone cut H&R springs before??
Not sure if I should cut 1/4, 1/2, or full coil for that extra inch.
Any suggestions?
Oh and yes I know a lot of people don't like to cut coils, but for 1", I don't mind doing it, and not worth the extra money for coilovers.
Any suggestions?
really? I thought H&R springs were already the lowest spring you could go with?
Why not just cut the stockers if you just want it dumped?
I have the eibachs on mine it is a perfect combo of looks, functionality and driveability. I am able to jack it up without getting it on planks before hand. Hit speed bumps without hitting them at an angle. And the performance is great. Have yet to rub anything.
Typically I like my cars slammed but it comes at a price. I did not feel like having a car that rode like *** and bottomed out and scraped on everything. Not to mention have a 5 step process just to jack the car up.
my money is going elsewhere on another project right now, so coilovers are completely out of the question. Ive had the H&R springs on since ive had the car (about 3 years) so im used to that ride, never had stock suspension. My tires are on the thinner side 245/35. I just hate seeing the 1'' fender gap, and I don't want to go with thicker wall tires. I don't think itll ride like crap with just a 1/2 coil cut off on the rear, the front I might be able to get away with a thinner rubber spacer between the top of the spring and the body of the car. we'll see. I guess since no one has done it, ill start with 1/4 coil first and see where it sits.
I think I might end up cutting my stockers down the road for car shows and what not, but I like the functionality of my eibachs for daily use.
OP I say get one size taller tires and cut a little off the springs. Taller tires will also help with the ride, because it will more than likely ride like *** once it is that low.
Swapping or trimming the rubber isolators should get you the results you're after. You'll probably rip our your fender liners over bumps though. I've done that with just H&Rs unmodded. I'd actually like to shim them up 1/2". My 245/45 tucks currently and I'd like to have it even.
So after almost 2 weeks of waiting for my bushings, I finally got them and was able to install and test drive hard, also got that extra inch, front might need to come down some, I'll wait until the springs settle. So far it doesn't ride much different than before. Also got around to...
Got rid of my silent magnaflow exhaust, and went straight pipe! Loud and so mean sounding! Just have to weld the magnaflow tips back on.
My carrier bearing was shot, so I cut it all out and welded a plate to the back with the bearing in the center (doesn't touch) and filled in the void with loctite sl 10 or something like that, its basically 30a polyurethane in liquid form. So far, it's great!! No more vibrations or clunks!! And only cost $10. We'll see if it holds up in the long run, regardless it's still better than the thin oem rubber housing for the bearing. Oh and I never had to break apart the driveshaft!
Anyway I'll post pics tomorrow, it's to late now.
