Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Question about the XM roof antenna
Old 05-11-2017, 09:02 PM
Mike ctsV's Avatar
Default Question about the XM roof antenna
Has anyone had to replace there's before? is it required to remove the headliner? Or can you get to it by just removing the rear domelight? my fin part is broken off the mount on the roof. Xm still works OK sometime. I got a replacement one and then I noticed the antenna part un screws off of the base. But the one on the roof of my car don't un screw, looks like it has two star bolts holding the piece to the mount.so looks like I just have to change the whole thing and I can't find anything online about it
Old 05-12-2017, 12:19 AM
vroom_vroom's Avatar
I believe the bolt under the dome light holds it
Old 05-12-2017, 07:54 AM
Bio248's Avatar
the XM antenna has a stud poking out of it and you have to take a nut off of it from under the headliner.
it's way easier said than done.
Old 05-12-2017, 06:14 PM
jmilz28's Avatar
I know cats like to chew on the antennas. Does that help? It didn't help me...
Old 07-26-2017, 09:47 PM
Mike ctsV's Avatar
This is the antenna I have on my roof, I took off them two bolts and that peice wouldnt come off, i was assuming i can just replace that fin part that sticks up, instead of the whole base
And this is my replacement antenna
As u can see this one unscrews, unlike the other one
Old 07-26-2017, 09:50 PM
Mike ctsV's Avatar
So im geussing i gotta remove the dome light and hope i can reach in and unplug the wires without haveing to remove the headliner, since the two antennas are different for some reason. Im guessing cause of different yrs. Stupid xm radio dont like to get signal alot since that peice is missing so i would like to fix it to listen to xm instead of all that crappy fm radio junk music
Old 07-27-2017, 12:50 AM
Vcaddy71's Avatar
This just happened to mine.....
Where did you pick one up? Cost? Mine looks like it has the two screws to remove it.
Old 07-27-2017, 06:30 AM
Mike ctsV's Avatar
I got it at a junkyard a few months back, dont remember the price, not more than 20 bucks i know that, and it came off a base model cts
Quick Reply: Question about the XM roof antenna
