Bottom Front Shock Bushing
Finally found my squeaking in the front of my car!! The shocks are still good but the bottom bushing that has the "plate" with two bolts at bottom holding the lower part of the shock on the lower control arm is shot. As I said the shock still rebounds good. Is there a replacement bushing for the shock?
HELP!!
HELP!!
I swear I've seen a poly shock bushing somewhere for our car.
Would something like this work?
https://www.summitracing.com/parts/r.../applications/
I could probably grab a junkyard strut to take apart next time I get up to the junkyard. It would just be an FE1 strut, but I imagine that bushing is configured the same regardless of which "grade" of strut it is.
Might be worth a call to see if front and rear are interchangeable... https://creative-steel.com/shop/cadi...hock-bushings/
Hell, for $65 I might pull one of each and eyeball it and if it looks the same, take a shot.
The following users liked this post:
jmilz28 (08-27-2020)
