Smaller Pully On Magnacharger
Can You Put A Smaller Pully On The Magnacharger And Get Alot More Boost. Has Anyone Done This And If So What Were The Results
Originally Posted by StealthV
Before throwing a different pulley on, check to see where your boost level is today. Too much and kaboom. ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I agree 10:1 and boost is not good more than 6
Triple that (what Stealth said)
Much over 6 psi and kaboom is the answer.
I'm running a 2.8" pulley because I wasn't seeing the boost I should (elevation possibly) and the 2.8" pulley brought me right to about 5.5-6 psi - right where it should be.
Substantial tuning has been done since the pulley change to make things run correctly. How much power am I making now? Hard to say, no dyno time available - but suffice it to say that I believe betweent he pulley swap, incredible StealthV (TM) tune and B&B headers I'm sure it is over 60 hp better than before
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
This guy put a 2.6" pulley on his magnacharger.
http://www.vseries.net/forums/showthread.php?t=237
You might need an alcohol kit if you go for the smaller pulley.
