wrecked my procharged CTS-V need help
I went around a corner hit a patch of sand on the road lost control and hit the curb.
![](http://i2.photobucket.com/albums/y42/HARAKAT/Image051.jpg)
![](http://i2.photobucket.com/albums/y42/HARAKAT/Image009.jpg)
With that said where do you guys suggest the cheapest and best place to get parts in order to get this car up and running again. I want to eliminate the common knocking noise as well that I had from the rear end when changing gears.
Thanks in advance.
1- Differential Assembly Part Number 15793786
1-LH Axle Assembly -Part number 89047648
1-RH Axle Assemby -Part Number 89047647
1-LH Upper Arm Assembly -Part Number 25684651
1-LH Lower Arm Assembly -Part Number 25745695
1-LH Knuckle Assembly -Part Number 88951999
1-LH Wheel Bearing (w/sensor) Part Number 89047669
1-LH Stabilizer Bar -Part Number 25762623
1-LH Linkit kit -Part Number 25740518
1-Shock Absorber -Part Number 25752922
1-Coil Spring -Part Number 25752977
1-Arm Control Support lower -Part number 25684655
1-Arm control adjuster -Part number 25737367
1- Cradle Assembly and 4 Cradle bush (comes with complete assembly) 25752705
1-LH Rotor Disc -Part Number 25750257
1-LH Parking Brake cable 25737611
1-Parking brake bracket 88951984
Thanks in advance.
Sorry to see your damage.
I have done the exact same thing to one of my supercharged rides before.
It happens.
On a positive note,
why don't you make the best of this situation and turn it into an opportunity to upgrade to the Madman/Thunder Racing 9" inch rear?
Good Luck.
It happens.
On a positive note,
Good Luck.
I definately agree...if you hafta put money into the rear end, why not upgrade it? Especially with the additional power from the S/C...it's just a matter of time before you have to upgrade it anyhow.
so if i were to go this route what parts could i use? so far i've been quoted by a local caddy dealer 5,500 to get all the parts.
http://www.thunderracing.com/catalog...cturer&mid=166
Put the Madman rear in or sell your car now,
as is.
That is the best advice you are going to get.
You might want to put a SERIOUS clutch in as well when they are doing the work.
Good Luck
as is.
Good Luck
Not sure what the rules are here so kick me if I'm out of line mods.
I just started posting on this site because I picked up an 06 CTS-V that has a bit of an issue with the roof. The rear is fine though. PM me if you'd like to make a deal on the rear. I'm in NY
Sorry to see that happened to you at least it is fixable.
See my post below
Ouch!
See my post below
Ouch!
A guy I worked with bought the car and it was his pride and joy. One day he came in and said a tree fell on the roof. I thought he was kidding until I saw pictures. I then asked him to find out the buyout if they totaled the car. He found it out after they deemed it totaled and I bought it plus gave him some cash for the trouble. I have been looking to see why they totaled it and can't figure it out. The car runs, drives straight and the rockers/frame I can't see any issue with. I think I am set now on putting the engine in my camaro and parting the rest out.
