Urgent Help Needed Wrecked Cts-v
I posted here exactly a year ago, about me wrecking my 04 Procharged CTS-V. Unfortunately at the time I didnt have the funds and was finishing my Supra. No insurance is what stalled the fix.
I went around a corner hit a patch of sand on the road lost control and hit the curb. (pics below)
With that said what dealer do you guys recommended I get the parts from? Who has the best prices. I want to eliminate the common knocking/whining noise from the diff as well.
What route would you guys take, since we all have this common diff problem? Throw an 06 diff in? Can it go right in without any extra problems?
I finally have cash in hand, just need the right help in order to get the parts.
Thanks in advance.
1- Differential Assembly Part Number 15793786 (not sure if this is the 04 diff)
1-LH Axle Assembly -Part number 89047648
1-RH Axle Assemby -Part Number 89047647
1-LH Upper Arm Assembly -Part Number 25684651
1-LH Lower Arm Assembly -Part Number 25745695
1-LH Knuckle Assembly -Part Number 88951999
1-LH Wheel Bearing (w/sensor) Part Number 89047669
1-LH Stabilizer Bar -Part Number 25762623
1-LH Linkit kit -Part Number 25740518
1-Shock Absorber -Part Number 25752922
1-Coil Spring -Part Number 25752977
1-Arm Control Support lower -Part number 25684655
1-Arm control adjuster -Part number 25737367
1- Cradle Assembly and 4 Cradle bush (comes with complete assembly) 25752705
1-LH Rotor Disc -Part Number 25750257
1-LH Parking Brake cable 25737611
1-Parking brake bracket 88951984
![](http://i2.photobucket.com/albums/y42/HARAKAT/Image051.jpg)
Thanks in advance.
![](http://i2.photobucket.com/albums/y42/HARAKAT/Image009.jpg)
Originally Posted by 2c5s
gm parts direct
on another note can the 06' diff go right in to an 04? What have they changed in the 06 diff? Is there any other route since to go since ill be changin the whole diff?
The 06 diff is a direct replacement for the 04. HOWEVER, running FI is going to destroy even the new and "improved" (hahahaha) 06 diff. My advice is throw the 06 in there and do not drop the clutch and be relatively easy off the line. If you can wait a while, there are several aftermarket approaches to throwing a beefier pumpkin between the rear tires (may or may not be an option for you, depending on your location/time frame).
i just wanna get that thing running. its been a whole year. i was hopin within a year someone would mass produce a solution to the rear end but aint lookin like thats gonna happen for another year.
Originally Posted by stkshkr
Call Luke Butler at Lindsay Cadillac (703) 647-8670
Luke's prices (and service) are fantastic. I'm a tenured employee at Cadillac Dealership (8 years) and Luke's prices are better than I get from my own parts department.
Originally Posted by SilveradoSS500
Get a ford rear end put in! 6k, I believe you get a choice of 3 different types of rears with this company in Baltimore!!!
