Tuning in Alberta
Uses a Mustang load dyno.
www.dynomotive.ca
He tuned my LSx powered BMW that ran at Race the Base (301 kph on realtime gps in car lap timer)
Tell him Trevor P sent you!
http://westersgarage.eidnet.org
When other shops know it will be a difficult tune, this is where they send them.
Not the cheapest, but ...
Heard lots of good things about Toma as well.
I have had 3 duramaxes, LS6, Ls2,6.2 Litre truck, a complete computer changeover on a 1984 crossfire....all have performed really, really well.
If all you heard was complaints about us, it wouldn't make sense that you'd buy something from us...so the lies stop here.
I installed the harness like Westers instructions said and then I brought my truck in to get tuned. I got a call from my tuner a short while later saying they couldn't get the fans to turn on and the relays were not wired properly. They pulled it all apart and rewired it at $100/hour and got the fans working. They worked for a short while but then one of the fans stopped working so instead of messing with it I just replaced it with a stock 05+ harness that has worked flawlessly ever since. I emailed pictures to Westers of the hacked up harness after but they just said that they can't see any difference. This was almost 2 years ago but if you would still like your hacked up harness I'd be glad to send it back.
I read good things about Westers up until my experience. Then I met some people who were not very pleased with their Westers tune and went for re-tunes elsewhere.
All harness are bench tested before they leave here. Too late to backpeddleIf you sent pictures to Tim, I never saw them. I'm not aware of a client in Edmonton (where you're from) that was unhappy with a tune from us, and if they went elsewhere--I'm unaware of it. We tune for 70+ different performance shops, including shops mentioned in this thread.
At any rate, I responded with the following quote to your email
with the hack job pictures.
"Doesn't look like our harness...sorry ? But we will replace it...Looks like you're the victim of another shop that
thought they knew how to wire the fan up. Where did the trigger wires for the relays go ?
However...you have to hook it up the way we tell you too...and your ECM has to be configured to run it, if you want the ECM to run your fans."
Lyndon
Westers Garage
I re-sent you the picture that I emailed you back in March 2010 and forwarded the email from that time as well.
I followed your instructions hooking up the labeled wires, got the ECM programmed by Horsepower Solutions in Edmonton and that fans still did not work. This leads me to believe that your harness was at fault.
I would be glad to send this hacked up harness back to your shop for a full refund. At least it would change my perspective on how your company deals with unsatisfied customers instead of simply calling them liars.
