Canadian Members We never leave because we have The Beer Store
An UPDATE for 2013 Emission
Old Jul 14, 2012 | 09:39 PM
tsench's Avatar
Default An UPDATE for 2013 Emission
i got this off a buddy of mine @ MIssissauga shop here the whole process was easy
they need 3 pictures of the car VIN, Rear end and cluster start up the car hook up OBD II computer read from there you allow 1 not ready so as long as no check engine light and they all ready you pass make it easy for us with HPTUNERS now for the guy did swap to 99-02 pcm make sure your pcm is reading your VIN on the door or front by windshield correct then shoulnt be problem
Old Jul 15, 2012 | 04:48 PM
spiro27's Avatar
i thought this hasent started yet. my shop still dynos them. this is great does it check if the monitiors have passed? or does it just check fornos ses light.
Old Jul 16, 2012 | 12:18 PM
tsench's Avatar
they started slowly now it check monitors and ses light
Old Jul 19, 2012 | 06:17 PM
spoolin turbo's Avatar
What about OBD1 cars? How will this work? Are they going to raise the exemption to start in 96/97 for OBD2?
Old Jul 20, 2012 | 11:31 AM
flame's Avatar
2 speed idle and 2500rpm sniffer for HC, CO
Old Jul 20, 2012 | 04:39 PM
No more Nox testing?
Also is this testing that the sensors are just there or are they testing that the sensors are actually functioning? I am not sure what the 1 not ready is actually measuring.
Old Jul 26, 2012 | 09:48 PM
flame's Avatar
Thats right no more Nox testing because the EGR valve is not generally used at idle only at cruise and a speed signal is required in most cases for it to be commanded open. The readiness tests are functional tests used by the pcm to help spot problems. They use various sensors to detect problems in the different systems.
Old Aug 19, 2012 | 07:28 PM
spiro27's Avatar
do they still 2 speed idel the car.
Old Aug 21, 2012 | 11:53 AM
flame's Avatar
After January 2013 98 and newer is plug in testing 97 older is 2 speed idle
Before January 2013 if the place is currently using the new system and the car fails then they run it the old way to see if it passes the sniffer test
Old Aug 23, 2012 | 08:24 PM
LETZRIDE's Avatar
are you sure it is 98 and newer? if so that blows because I have OBD2 in my 96 and I'm laughing if this is all thats needed to pass.
Old Aug 24, 2012 | 11:32 AM
flame's Avatar
Yes 98 and newer 90% of the 96-97 vehicles were not fully OBDII compliant
Old Aug 25, 2012 | 09:40 AM
LETZRIDE's Avatar
son of a, why couldn't they just say any car that was OBD 2 equipped??
Old Aug 26, 2012 | 10:39 AM
Speedy's Avatar
Is it possible to pass the 2-speed idle test with a 3000 stall?
Old Aug 26, 2012 | 06:18 PM
flame's Avatar
Because most of the 96-97 don't have enhanced EVAP, misfire detection, catalytic converter monitors that function. OBDII had a transition period and until 98 most of the manufacturers were dragging their feet.
flame's Avatar
Yeah my 3600 passed just fine!
Old Aug 27, 2012 | 12:26 AM
LETZRIDE's Avatar
mine passed on a 3200 stall until I went and threw in my larger cam. the driving portion the car is clean as hell, it's the idle that is totally off the charts on my car and which screws everything up.
Old Aug 27, 2012 | 06:58 AM
flame's Avatar
Did you raise your idle to the 1200 rpm limit?
Old Aug 27, 2012 | 10:24 AM
LETZRIDE's Avatar
Ya, I think it may be the overlap in the cam. My old cam was 210/220 .512/.512, my new cam is 230/240 .512/.512
The old cam was a joke to get it to pass, the new cam I think the extra overlap just does it in, because the numbers weren't even close to the limits on idle lol
Old Aug 27, 2012 | 06:22 PM
Speedy's Avatar
My cam is a 276HR-12 which is 224/230 @.050 with a 112lsa, .537/.544 I'm wondering if the 112 is going to be a problem. What is your lsa?
Old Aug 27, 2012 | 07:50 PM
flame's Avatar
Yours should be able to pass with good cats and tuning. LETZRIDE has a 3800 6cyl
