Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
what to do now? had a problem..
Old Dec 12, 2010 | 01:39 PM
LS_10's Avatar
Default what to do now? had a problem..
Well I not sure what to do now. I blew a head gasket and water in the oil...not sure if i should have the heads checked and flush the engine and see how long I get lucky for or do a real motor now, go through this one and freshen it up then sell it.
Where's a good place to get some decent prices on short blocks bigger cubes then this little stock LS1 i've been playing with?
Old Dec 12, 2010 | 04:56 PM
ZONES89RS's Avatar
In-Zane Moderator
You can buy a kit or buy a short block, i know there was a deal on the 6.0 block with the 427 stroker kit:
https://ls1tech.com/forums/sponsor-s...er-3599-a.html
390 ci:
https://ls1tech.com/forums/forced-in...rankshaft.html
416 from a LS3 block:
https://ls1tech.com/forums/sponsor-s...st-4399-a.html
There are some general ideas for some real cubes that would be a whole different monster.
Old Dec 12, 2010 | 04:57 PM
ZONES89RS's Avatar
In-Zane Moderator
Oh yea, as for the current engine, i would have the heads checked and swap gaskets, put it back together, flush the engine, change the oil and get back to beating the **** out of it.
Old Dec 12, 2010 | 05:31 PM
LS_10's Avatar
Thanks man! I'm going to buy one of these bigger cube set ups and go through the current one.
Old Dec 12, 2010 | 06:03 PM
ZONES89RS's Avatar
In-Zane Moderator
Do what you gotta do man. Was the head gasket original? I assume not, what head bolts?
Old Dec 12, 2010 | 06:04 PM
3pedals's Avatar
you will probably have to do a cleanup cut to the heads to get them flat at a minimum.
Old Dec 12, 2010 | 08:14 PM
NemeSS's Avatar
theres many options out there. depend on ur budget. look into a 6.0 iron block based build or if u have the $. a aluminum 6.2 based engine. a 415-417ci motor with a 4in stroke crank. if u want to keep an aluminum engine in ur ride
Old Dec 12, 2010 | 09:03 PM
LS_10's Avatar
It was a GM MLS gasket, I have ARP Head studs so i'm not sure how it happend. Ya i'm going to have the heads checked and resurfaced. I've been thinking of the cast 6.0 but I really like the less weight of the aluminum.
The budget is good for another engine build, I had money put away to have it caged and painted guess that will just have to wait.
Old Dec 13, 2010 | 12:27 AM
Oldsmobility85's Avatar
Rather see it on the bumper than shiny. LOL.
