cold start carb problems?
I got a pro systems carb for my car and when its real cold outside its really hard to start. Its a race version so it has no choke. Im really new at carbs and wondering is theres a way to make it start a little easier. Never really figured the carb out anyhow. When its warm it starts fine but seems like to me it takes a little while for it will idle on its on without going dead. Is there anything I can do or is that just a race type carb?
In-Zane Moderator
Back off the primary idle circuit screws about 1 to 1.5 turns on the primaries, that will allow the idle mix to richen up allowing easier starts, they wont be perfect but with some time and tuning, it will not be bad. It is how mine are, they will start in the cold and do not take ling to idle on their own.
yes your fronts are primary and the rears are secondaries..... Id say 1-1.5 turns from all the way in. if you can live with the cold starts they usually like .75 out .1-1.5 is usually a bit rich richer will make it easier on cold starts.
key4, I've got the same problem and I've just been living with it. I've got to say, those idle screws are very sensitive! I can make a 1/8 turn adjustment and change the AFR over 2 full points so be careful doing this. The original setting of 1.5 turns out gave me a 9.5:1 AFR and within minutes had fouled every plug so bad it would not restart at all.
I've thought about making a "cold start solenoid" to bleed in some air and raise the idle speed. I found some 12V air horn solenoids that would work using a Holley jet in it for a restriction orifice to control the amount of air. Still considering the wiring side of it...
Personally I'd rather a good running warm motor than a good running cold one and too rich warm motor. You have no choke, tap the pedal until it catches and builds heat on its own. Zones says 1 turn more than what you have now is a big change, i'd be looking into a 1/8th turn to 1/4 turn at most.
I have to agree with the others, with my carb 1 1/2 turns will be massively rich. Mine sit a little over 1/2 turn for a 15:1 idle mixture.
Also like said above just keep pumping the pedal and reving the motor till it heats up.
The alternative is to switch to a choke carb in the cold months.
Ok guys thanks, I will play with the idle screw alittle but thats what I usually do is just pump the pedal till its warm. Its just real hard to get it to start when its cold. I was just wondering if this is a common problem or not.
In-Zane Moderator
With no choke, it is very common, life of a race ready carb. Every carb is different, so the amount you back off will be determined by your particular carb. I have 4 corner idle and i think i run 1 turn out on the primaries and 3/4 out on the secondaries if i remember right.
Thanks, yea I think mine is too high at when the key is on till 500rpms. Also around what fuel pressure are you guys at? I got mine set at 8 but when I when I first start the fuel pump its around 9 or so but it falls back down to 8when it warms up.
yea I really trying to figure the whole carb and fuel pressure thing out. I have a areomotive a1000 and a bypass regulator. I have the gauge coming off the regulator and really dont think its working right. Reason I say that is when I adjust the fuel pressure down it just wont go any lower than 7.5. I can almost screw the adjuster all the way out of the regulator and still reads around 7.5. I really think I need a new gauge.
run a quality gauge not one of those 1.5" diameter cheapies. Also you need to kill power to the pump and turn it back on to recheck fuel pressure everytime you make an adjustment. If it wont drop enough at idle then you have a return line restriction somewhere or the line needs to be larger.
May not be the carb at all.
Try to start using a jump box to improve cranking voltage.
The MSD needs 10 volts to fire the engine.
My car would not cold start below 50 degrees F with an Odyssey 680 race battery. Put the jump box on and it would fire up , once the oil was warm it would be ok the rest of the day.
Dave
Dave
