6.0 carb and distributor
I picked up a lq9 out of a 04 chevy 2500 and i want to put it into my 66 buick,but i want to carb and put a distributor on it. can anyone help me with the info i need to get started. And can i mate a older th400 to this motor. thanx
If you go to the GMPP online catalog you will be able to find all the part numbers for the LS front distributor set up. You can go through any GM dealer to order once you have your part numbers. I think the distributor route is fairly expensive. Good Luck
If you go with L92/LS3 heads, here's the GMPP intake PN#: ((SQUARE PORT...not cath))
Parts #25534401
L76/L92 4-Barrel Intake Manifold GM Racing design for use on 'as-cast' rectangle port Gen IV cylinder heads As-cast design requires no porting for maximum performance Includes mounting bolts and instructions Uses L92/LS3 carb intake gasket set P/N 19172114 Machined for 4150-style carburetors and has 3/8' NPT vacuum boss Also available with injector bosses P/N 25534416
Note: LSX Ignition Controller P/N 19171130 is required for carbureted applications.
Are you leaving the stock LQ9 compression, heads and cam?
Parts #25534401
I run the edelbrock box and i turn my 6.0 8250 every saturday night. i have blown up a few due to poor oil drainback at those RPM's but they will take it.
25534401, 60, 6061, build, carb, carbd, carberated, carburated, carburator, carbureted, chevy, distributor, gm, intake, kit, ls1, manifold, msd, pn
