?? Heads ??
Thanks Steve
I swapped out the springs on mine as my cam has .610/.617 lift and got the gold dual spring kit (.650) with titanium retainers, locks, and all from Patriot.
To the OP, cam selection is important with the L92 heads. The intakes vastly outflow the exhaust. You can go into some of the FI sections here and read till your eyes bleed about mid range torque and cam selection with the L92 heads.
Also L92's require a 4 inch bore, so 6.0L and larger only. They also require an L92 intake. That might have a lot to do with the popularity of the 243 heads.
some pics of the heads and intake
yeah I planned my combo around it so to speak as I wanted carb'd...but with L92 heads and a carb....most available were single plane. When I found this intake in the 2009 catalog...I waited. Then it was in the 2010 catalog...impatient I had calls into 2 Chevy dealerships w/parts guys watching for it for me....and I finally got to order one in mid June 2010. I'd guess I got one of the 1st available and was just under $500.
