Carb problems - Idle AFR? - My car thinks fat is phat!
I was playing with idle AFR today and my car drives better and the idle sounds better at 11.1 to 11.2 air fuel ratio. I tried it leaner but she is just not happy up there.
What are you all setting yours at?
I'm in the 15:1 A/F ratio range with my camaro. Of course I'm running 28 degrees timing at idle, which will clean up the a/f ratio quite a bit compared to if I'm only running 20 degrees or so. So what are your guys idle timing at? 11:1 is extremely fat, and sounds off to me.
I took an old 650 Mechanical Secondary I bought off of E-bay, rebuilt it and put it on the car today. Viola! I can set the idle at any AFR I choose and no hesitation at tip in. It cruises between 13.5 at 14.2 and WOT is between 12.2 to 13.1 depending on the situation but generally settles in at 12.4. There is no bog, no hesitation and it drives like a dream. I did not have to change jets, bleeds squirters or pump cams. It works perfectly just as calibrated from the factory.
What is wrong with the Pro Systems carb? I suspect maybe the idle transfer slot is not working. Patrick wants me to send it in so he can have a look. I may pull the base plate first and just check to make sure the idle transfer slot is machined right.
While it is hard to tell by seat of the pants, the 650 does not feel as strong as the Pro Systems carb and the throttle response is not a violent either. So, I will say that I think the Pro Systems carb definitely makes good go fast, it just has some other metering system problems.
Either way, it is good to see the car run so well and so clean around town. Too bad my exhaust system, plugs and combustion chambers have accumulated so much soot running the other carburetor. It is also nice to sit at a light or pull into the garage without choking to death on hydrocarbons. All in all, Happy Day.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Nice to hear that you made some significant improvements. Is the 650 just a "standard" stock carb?? I was surprised that you had AFR issues with the dual plane. I have the same intake and am keeping my fingers crossed when I use the 750...although it is an Edelbrock carb.
I also ordered a Holley 750 HP conversion kit for the 650. We shall see how well that works.
