Carb guys- help needed lsx454
hey guys so heres the deal. Im building a 67 camaro and just had a son. my funds are not what they used to be. I was setting the car up for fuel injected, but im not to far into it and think I can change pretty easy if there is some savings to be had. Heres what I know so far as far as price goes
tb - 550
wiring /all sensors - 1200
fuel injectors - 550
fuel rails - 190
Carb-??
Wiring-??
Intake -??
anything else needed?
I am basically trying to get an idea of what I will need to go carbed if I was to. I know I will have to get my fuel pump changed out of my ricks tank as I have a high flow atm. I can also sell my fast intake to get some money together for another intake, carb...ect. Im basically looking to make a real list and see what it will cost approximitly. Thanks for all the help, Steven
tb - 550
fuel rails - 190
Carb-??
Wiring-??
Intake -??
Old School Heavy
Holley HP 950 $750
Carb Heat Isolator $25
Carb inline fuel filter $35 - $100
Holley Regulator $35 - $85
MSD 6010 or 6012 $350
Air Cleaner Assembly $25 to $100
Fuel Lines and fittings Steel lines & Brass Fittings - $75
or
Fuel Lines and fittings Russell/Aeropquip - $250 or more
1 carb rebuild kit for spare parts and when the gaskets tear when changing jets. $40
A couple packs of jets for tuning $20
If you are plumbed for a return line, you can use the same fuel pump with a by pass regulator.
What kind of trans are you running? If it is a late model automatic, you will need a trans controller. If it is an older automatic with detent or throttle valve, you will need brackets for the throttle. If it is a manual - no worries.
or
Holley HP 950 $750
or
or
Old School Heavy
As I said, you can use a high pressure fuel injector style pump if you have a return line fuel system and a carburetor style return fuel pressure regulator. This is what I have.
For the amount of difference in price, I would really ask myself are you a carb guy. Carb set ups are really a different final product than fuel injection.
Fuel injection, once it is tuned properly, is a set it and forget it deal. Cold starts and weather changes are all handled by the computer. No worries.
Carbs can be fussy when you first start the car. Getting one well tuned takes some know how. And, they might screw up every so often with a needle and seat failure or such.
If you are a tinkerer and you don't mind lovin' on the carb now and again, then great. If once the car is done, you don't want to have to mess with it. I would stick with injection.
super victor or mast intake if you have the $$$
1000 or 1050 quick fuel 4150 Q series mechanical secondary carb minimum
then a QUALITY carb pressure regulator with return since you're running a high pressure pump. The return line should be -8 at least, along with the send line.
Or buy a magnafuel pro star 300 pump, sump your tank and run a single line up front to a magnafuel regulator that is a dead head. Might cost more initially but you save on all the an fittings and the extra line ran to the front.
I would NOT run a vic jr on that many cubes, but that's just me.
tb - 550
fuel rails - 190
Carb-??
Wiring-??
Intake -??
tb - 550
fuel rails - 190
Carb-??
Wiring-??
Intake -??
Victor Jr would be the intake for that set up.
Some of your estimates are way too high. Injectors are around $400 and you can get your wiring and sensors for half what you listed. Just get a good used engine harness off ebay and mod it yourself. Right now, Racetronix has an injector sale going on 42lb injectors for $35 each.
Looks like around a 2 inch cowl to me, correct? I have a 2nd Gen Camaro (73) and to fit a Vic Jr under my 4 inch cowl hood, I have to run a drop base air cleaner. I know it's not a rrue apples to apples comparison since mines not a first gen, but should give you some frame of reference. Maybe 3pedals can let you know how his Victor Jr fits in his 67? I know he has a cowl hood but not sure how high his is. Of course from there you'll then have to determine how much taller the Super Vic is over a Jr. I know that info is on here somewhere too. Best of luck.
take your time save your money and build it how you want, you dont need to have the thing up and running by the end of the month or anything, you obviously work hard and play hard too, so just build it to how you want. your talking a few dollars saved by going carb then you have to sell the fast manifold aswell. its only a few dollars difference.
I think it took me 3 years to get my crate motor running. 2 at least. I wouldn't worry about warranties. Chances are nothing will happen and even worst case it won't take $9500 to rebuild any damage.
Some of that stuff, like fuel lines and the fuel pump, you have to buy for either option. So not really a discriminator. For EFI you will need to budget for a lap top and some type of tuning software. If not you are paying someone hundreds of bucks everytime you change something significantly. For the carb you will most likely want to invest $200-$500 in a wideband O2 sensor. They make a huge difference tuning the carb.
Like someone said for the EFI sourcing used carb stuff will save you a bunch of money. You are at a bit of a disadvantage cause you do need such a big carb. But IMO buying a used carb is less risky than buying used EFI stuff.
Carbs are not that finicky, but they definitely not as set and forget as EFI. If you aren't spraying it or tuning for every last bit of HP then you can easily find a good overall tune that you don't need to monkey with too much. The carb will be cheaper if you do go up in HP for some reason. Jets are much cheaper than new injectors.
Holley HP 950 $750
or
or
Old School Heavy
Hey speedtigger when you said holly 950. Which one would be best for my setup? I have a lead on a 80496-1 http://www.jegs.com/i/Holley/510/0-80496-1/10002/-1 for around 500..and was considering but what to make sure it the correct one for me...thanks Steven
There is also a holley street 950 HP http://www.holley.com/0-82951.asp
The street 950HP might be a better choice as it is calibrated for the street. This likely means a leaner idle and is set up to run better with smaller camshafts whereas the race version will likely be fatter cruising around and may not be as happy at idle with a smaller street type camshaft.
The street HP can be bought brand new for $550:
http://www.summitracing.com/parts/HLY-0-82951
I am not sure exactly what all the calibration and features differences are. I am sure that the 80496 could be tuned to meet your needs. It just might be easier to start with a street HP.
My Vic jr with a aircleaner with a drop plate the top part touches the slope from my cowl, but now im gonna have to make some custom setup since i put a spray plate on now...I have a 2 1/2 Cowl hood on my car
So after doing some reading and digging I can not seem to find the super victor that fits ls7 heads. Can someone point me in the right direction please?.. . Also Im guessing that any of the options for going carbed are going to run into clearance issues with my hood correct? Some pictures of setups would give me a better idea.. Thanks, Steven
Look at the GMPP LS7 intake 19244033, as that is what is recommended for the LSX454.
