Ls1 or lq4
Ls1 or lq4
I have an lq4 in a 93 mustang. Stock bottom end with 243 heads un
ported a234-246 601-606 on 109 cam victor Jr and a 850 Holley.car went 11.03 at 123.2. Now I just got a2004 ls1 and was going to put my heads cam and intake on it. Will the less weight and more compression make up for the less cubic inches or will it be slower.
no replacement for displacement you can always sell the ls1 for good money the get some flat top pistons bump up the compression then get some more heads from gmpp l98s will cost around a grand..
Hard to say. The larger bore is suppose to help "unshroud the valves", whatever that means. I think it means improve breathing. So with the same induction parts and I assume exhaust it ought to be an interesting test.
You need to drop a lot of weight to make up for any loss in HP. Turning corners is another matter.
thats why you go with the lq9 piston and heads get the bump in compression and come down on the cam lobe height and duration. the other way to go is stroke it. 4.125 crank with matching connecting rods and piston a trip to your local machine shop should be relatively cheap since the engine is running now.. the sale of the ls1 will again pay for your now much stronger 427 small block.
try this http://www.texas-speed.com/p-2148-ca...od-length.aspx
Sell,the unported 243s, sell the ls1 and get a set of cnc ported 243s milled. For even higher compression.
With the improved flow,and higher compression it will wake up the motor even more.
No need to swap pistons, just have heads milled. Alredy have cathedral port intake. So no need to go with rectangle port heads
