How much power?
Ok I've decided to go with the edelbrock 2216 cam,ported 706 heads ,stock 5.3 bottom end,Vic jr intake,Holley hp750,1 3/4 long tubes.what kinda power do you guys think this will make?. The rest of the combo is 4500 stall,3.73 gear.th350 trans.3500 lb vehicle weight.e.t.? Once I get it done I'll run it and let you know how it did.
About tree fiddy. Damn succubus' are stingy as ****. In all honesty with a 4500 stall your not gunna be makin high numbers on the dyno but I bet it will move at the track. Post some times when you do run
