started my swap
I recently started my swap. You can view it by click the link in my sig. Ill be going the carb route so i guess i will start posting in here. I purchased the vic jr intake today so that should be here soon. I just sold my carb the other day (pre-mature) god i hate when that happens
so i guess ill finally get the holley double pumper ive been wanting to get. I got an lq9 out of a 2002 escalade. im not exactly sure what reluctor is in it but i think i need the 6010 msd for it? also i didnt see a crank position sensor so i dont know how i am going to get everything to work together without the distributor.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
well i guess i feel like a dumb ***. after a quick search i was able to locate my crank position sensor and my cam position sensor. here is my question now. with hooking up the 6010 msd do i have to use the connectors from my wiring harness that was on the engine and splice a bunch of connections up? I was looking at the pics of the msd on Jegs and it looked like it comes with the new wiring harness req'd to plug everything up. is this true?
Yep msd 6010 comes with everything you need, only other wiring harness is the original one for starter, igntion, etc. setting up the msd is so simple it's almost too easy. Mine fired on the first try due to the simple nature of the harness. That lq9 is a great engine to start with, good choice. Also I would go with a vacuum secondary carb unless you have a manual or a really light car.
Vacuum secondaries for fuel economy? Oh you just made my day letting me know that it comes with everything including the harness. That is awesome.
Well my Vic Jr intake is out for delivery today. I need to finish getting the engine cleaned up today so i can paint it. I need to list all my extra parts on CL so i can make some money back lol i need to get that 6010 setup and carb asap lol
![](http://i48.tinypic.com/ff04yo.jpg)
![](http://i45.tinypic.com/33kd7ax.jpg)
I cant believe its the same motor i started with. the intake is just settting up there for now. i live in base housing and an inspector came by today and **** on my parade so i had to stop until they quit harassing me for being a mechanic.
Shiii makes me want to get out in the garage! Motor looks good. How did you paint it? Where did you read about cutting bracket? Link? Keep it up, looking good!. Btw is it going in that Nova?
Thanks. I have to keep it hush hush for a bit they are onto me for working on it on base. I still have to do the bell housing and motor mounts and i can put it back in, well i have to get a fly wheel too lol
Ok so i was able to work peacefully with my garage door shut today. The engine is good to go for now just need to get my hands on a flywheel and im picking up the frame mounts tomorrow that should work out good down in my engine bay. i was able to get the JW bell housing installed without removing the trans and flipping it upside down and pulling the pump out and all that unneeded extra work. anyways here are some pics.
![](http://i48.tinypic.com/34ql4xv.jpg)
![](http://i45.tinypic.com/35l52qt.jpg)
i cleaned it really good and prep sprayed it. i taped everything off and primed it and then painted it with two coats chevy red orange and two coats clear. The bracket uhhhh i didnt read anywhere about it i just didnt need power steering or ac so the power steering bracket i figured i would just cut it down and get rid of the pulley and make it look more appealing to the eye for now. i will get a different front drive system down the road just have to save some money. I think im into this swap at right about 3k so far so im not doing to bad i dont think.
Ok i was able to pick up a flywheel today off CL and my "Q" converter will bolt directly to it. My question is am i still going to need the spacer everyone is talking about for this to bold to my th350 trans. From what i have read all lq9's have to shorter cranks.
I was reading a different thread that said the lq9 was pretty much lsx ready and didn't require the spacer for it? Did I read it wrong.
