How much vacuum at idle?
I'm not sure if headers and a better flowing intake will cause a drop In vac readings. I'd think so but someone might chime in and correct me if I'm wrong. All I know is if you hold the engine at say 2000 rpm the needle should be stable and not bouncing. I couldn't tune my carb with a vac gauge tho. When it read better vac the carb was way out of wack. I'm sure yours is fine tho with those mods you seem to be ok I'd say
