lq4 cam/carb
What difference in cam setups are you guys running with carbs? I have a stock 6.0 bottom end with 317 heads milled .02 and .04 gasket I was looking at tick performance sns stg 2 mild version 226/234 .590/.600 110+3.. what do you guys think of that setup? Behind it will be a th350 with 3200 stall. Mainly used on street not a dd but would take to the track everynow and then. Will a 750cfm carb like that setup on a single plane intake?
Old School Heavy
Have you called Martin at Tick yet? If you give him all your build info, he can spec out a custom cam for your setup and Comp will grind it a few short days later and drop it at your door. My cam arrived before my push rod/spring kit arrived. Just a thought...
Do yall think I would have enough compression to run that cam if I just did the head gasket and not mill them? If I don't should i run something more like 223/227 .610/.610 111+2? I just don't want it to be a dog down low
The best thing about my smaller TorqueMAX cams are they create awesome dynamic compressoin. With 10.8-11.0:1 static compression the dynamic compression with the stage two is at 8.7:1-8.9:1 which IMO is perfect for pump gas. Higher dynamic compression with the smaller cam along with the overlap the TorqueMAX cams have, are how the "SNS" cams make so much torque.
Hey martin I'm using the Wallace racing calculator and if I'm doing everything right the mild stg 2 cam closes about 65 degrees ABDC. If I'm just running the head gasket static will be around 9.7:1 and dynamic will be around 7.65:1. Does this sound about right and will that be too low? There may be a better way to calculate this also so feel free to enlighten me! I know I sound like a woman asking all these questions but I like my **** right ha
