Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
First trip to the track
Old May 14, 2013 | 06:59 PM
LQ4BU's Avatar
Default First trip to the track
Hey guys,
Over the winter I completed a LQ4 swap into my 79 Malibu. I was a bit hesitant at first whether to use the carb off my old 406 sbc or stay with the fuel injection that came with the 6.0....but now that its all done, and thanks to all the info on this site....I am more than satisfied that I carbed it.
It's got a TH350, Ford 9in w/4.10 gears, 750 mighty demon carb, Vic Jr intake, MSD 6010 box, and 275/60 MT drag radials. Recently took it to the track for the first time this year...ran a best of 11.83 @ 109.97
Besides the carb, headers, and intake, the 6.0 is bone stock. I just cant believe how good it runs. Entered all my info into one of those drag calculators, and it says I have around 360-370 hp at the crank.
Thanks again to all the info on here...I couldnt have done it without.
Old May 14, 2013 | 08:07 PM
5.3/c10's Avatar
Sweet, runs good
Old May 14, 2013 | 08:39 PM
67RS/SSx2's Avatar
Wow, that's fantastic!
What does she weigh and what rpm stall are you running?
Old May 14, 2013 | 08:53 PM
LQ4BU's Avatar
Thanks!
With me in the car...weight is around 3150
Convertor is a Hughes 3000 stall
I had to play around with the accelerator pump squirters for awhile to get rid of the lean bog, but with .40 front and back, and pink cams on the 2nd hole it works good now.
Old May 14, 2013 | 09:27 PM
ZONES89RS's Avatar
In-Zane Moderator
Nice work! Cam and bigger converter time! We went 11.58 with a similar car. Torqer v2 cam, 3600 converter with 3.73s. That was one pass. Didn't know he pulled timing way back and it had a small 650 vac sec.
Old May 30, 2013 | 06:53 PM
newschool72's Avatar
Wow that car works good! 11 sec pass at less than 110 mph. Congrats!
Old Jun 2, 2013 | 10:39 AM
wildcamaro's Avatar
Nice pass bro
Old Jun 3, 2013 | 11:17 AM
BSmiff's Avatar
That thing is flying bone stock man. Congrats.
Old Jun 3, 2013 | 05:11 PM
Doug G's Avatar
Congrats Got to feel great on a stock motor Just think about once you add a cam LOL
Old Jun 4, 2013 | 08:24 PM
jleews6's Avatar
The car is running great for what you have but I think it might be laying down up top. Your 1/8th mile ET and MPH show that it should be running around 11.50s@114.
I wonder if its the tune,the motor? or is the 410 gear to much for the stock cam? I bet it would pick up a ton with just a cam change.
Old Jun 5, 2013 | 06:29 AM
I noticed the same thing. I just chalked it up to weak HP #s. It would scream with a cam swap up top, but the 3000 rpm stall would most likely kill the 60 ft with the powerband shift that comes with a fatter cam.
Old Jun 6, 2013 | 12:57 PM
jaywill's Avatar
Congratz !!!
Old Jun 7, 2013 | 08:46 AM
onefast84's Avatar
Nice runs, what jets and timing are you running?
Old Jul 28, 2013 | 11:04 PM
LQ4BU's Avatar
Sorry for the late reply.
Timing was total @ 34 deg Jets were 75 -85 that day....air was extremely good...best to date is 11.77 @ 110.78
I think its the stock cam/valve springs....she doesnt like to go over 6000. I think over the winter I will see about a camp swap.
Old Aug 6, 2013 | 08:21 PM
Joye227's Avatar
How's your suspension setup?
Old Aug 7, 2013 | 01:13 AM
windmill's Avatar
That's the same jetting I have in my stock mustang motor,,, I tried 6000 shift points it slowed down,, 5700 was best for mine,,,, I was only leaving at 2100 but it would flash 3400, I just ordered my cam from tick today and doing some port to my 799 heads I just got,
Old Aug 9, 2013 | 08:09 PM
TXsilverado's Avatar
running 11's on a stock cam must be nice. hoping my head/cammed setup runs as good as some of you stock guys! zone needs to get off his *** and come finish my truck.
Old Aug 9, 2013 | 08:27 PM
Blackpanther99's Avatar
Anymore updates?
