Nirtous with the msd 6010
Hey guys, looking for a bit of advice here.. Im not sure how to wire the ign. box into the nitrous system to utilize the timing retard.... I know someone has to have done this before.. I'm new to the N20 scene and dont want to hurt anything by doing something wrong here.. any insight would be great!!
Nice I knew there had to be a good way of routing it! So just to make sure I got this right. You run the + retard from the box to the solenoid, so that when the N20 is activated it automatically retards the timming? That sounds about right.. Are there any other things you guys run with it? like a window switch? I just want to make sure I dont screw this up. Or any beginner tips you'd like to share?
In-Zane Moderator
Yup, I connect it to the same 12 v source that activates the N2O. I run a MSD window switch that only comes on at 3000 and off at 68-6900. Stand alone fuel cell with 100+ octane that will dedicate higher octane to prevent detonation and eliminate worries. I run a micro switch on the throttle and a button so I have to be wide open throttle AND hit the interior activation button. No mistakes. I also run a purge to clear the line of air.
Ok good so at least I know im on the right track then with this.. What all did you use for the seperate fuel system? I'd like to do mine up in the same form, but idk how often itll actually get used and if i can even afford to do it that way right now.. Still working all of the tuning kinks out yet, but that is getting close. after that there are still a thousand more things to do..
Hey sorry to jack the thread, but zone and anyone else on here using spray what system are you running? I am interested in adding some nitrous to my set up and just looking to add a 100 shot nothing crazy. I was interested in the zex kit with perimeter plate or just keeping it basic with the Nitrous Express mainline kit and adding a bottle heater. Also, interested in the Nitrous Outlet puck that they mount at the bottom on the manifold.
www.nitrousoutlet.com/nitrous-puck
Is it worth spending the extra money on the better kits or does a budget kit work just as well?
no regulator?? ok.. Ill have to look into that. How big of a fuel cell do you run for the spray side of things? And I'm working on getting the Zex kit in mine.. So far the components look good/ like most others I've seen.. Cant say on functionality yet though...
