Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Beater build s10
Old Nov 19, 2013 | 09:56 AM
The stunningman's Avatar
PS fits no problems just use either a 300 6 cylinder F100 van pulley or fourth gen 3.8 f- body pulley. they are smaller in diameter and clear the box. The biggest question is are you going to run AC, if you are the box will most likely need to be notched as well as the lower PS of the frame. If not the radiator can be moved forward allowing room for some decent cooling fans.
Old Nov 19, 2013 | 11:06 AM
TXsilverado's Avatar
Originally Posted by ZONES89RS
Hahahhahaah, well, you need to find motivation somewhere. I was hoping riding in the murderstang would have been enough.
get your *** to my house and tune my carb...i cant keep it idling long enough to let the thermostat open to get the cooling system going...i'll talk to you about your rear options, you can check out some **** that i did/used and did i mention my carb runs like *** and i dont know what to do? LMAO.
my crank sensor wire runs extremely close to a plug wire...i wonder if that is causing any weird issues. i also havent wired my alternator yet so the lower voltage could be causing funky things.
here is proof that it moves under its own though. i backed it into the driveway and back into the garage about 10 times just for the hell of it hahaa
Old Nov 19, 2013 | 11:24 AM
ZONES89RS's Avatar
In-Zane Moderator
We will see, thanks for the heads up. I am going to go as cheap as possible as far as headers. The BRP are double the headmans, so that's the way for me to go at this point, but that can change:
Old Nov 19, 2013 | 11:36 AM
ZONES89RS's Avatar
In-Zane Moderator
When you need me to come by?
Old Nov 19, 2013 | 12:07 PM
windmill's Avatar
Dang zone you have more projects to work on, just like me... its hard for me to get in the mood to work on them,,, I have my 67 chevelle, my 72 chevy truck, and my wifes 66 mustang...
the little s-10 truck looks good,,
Old Nov 19, 2013 | 12:17 PM
beggers can't be choosers. let me know when you can make it and i'll be there.
Old Nov 19, 2013 | 02:46 PM
ZONES89RS's Avatar
In-Zane Moderator
We let me know when you have a chance and I'll make sure the wife won't be pissed off, she can't say I didn't give her a heads up. Lol
Old Nov 19, 2013 | 03:32 PM
snook's Avatar
These the headers you're gonna run?
http://paceperformance.com/i-8378313...p-headers.html
I almost got them, but had some extra cash so I went longtubes. I bought the 94-03 in frame ones though, don't like the tubes outside the framerail
Old Nov 19, 2013 | 05:21 PM
ZONES89RS's Avatar
In-Zane Moderator
How much were they? Yea, those are the ones I am considering at this point.
Old Nov 19, 2013 | 05:25 PM
snook's Avatar
700 shipped, lol. Brps
Couple hundred more, but longtubes. uncoated and wrap around the framerail
http://paceperformance.com/i-8379406...p-headers.html
Old Nov 19, 2013 | 05:32 PM
ZONES89RS's Avatar
In-Zane Moderator
Not bad, may go that route for the hell of it. 489 is not bad. Just not sure about the details, as in "must loosen cab and blah blah blah to install.
Old Nov 19, 2013 | 05:45 PM
  #32
snook's Avatar
Yeah Ive read that, brps are just hedmans coated from what Ive read. Instructions with some details on body lifting under the mount kit they sell
http://www.brphotrods.com/mm5/mercha...ory_Code=CNV12
I didn't have to raise the body, it was tight, but the trans/engine went right in
Those 1 3/4 ones only have 1 tube outside frame rail, 1 7/8 have two tubes outside
Old Nov 19, 2013 | 06:00 PM
  #33
snook's Avatar
Id check shipping prices/availabilty on those at pace too, they may *** rape you on shipping, not sure. And they may not have them made yet. It was 30 bucks from brp so shouldn't be much more than that, and took em a month or so to build them
Old Nov 19, 2013 | 08:08 PM
  #34
ZONES89RS's Avatar
In-Zane Moderator
Damn, well, maybe it took a month to coat them? Lol
Sure appreciate the heads up snook, folks like you make projects and this little corner of the site what it is.
I'll do some calling around to them as soon as I have cash. Which should be by the end of the month at the latest.
Trying to figure out if I'm going to use a explorer 8.8 rear as is or have the long side shortened so I can use a more original wheel offset.
Old Nov 19, 2013 | 08:16 PM
  #35
snook's Avatar
When your back is broke you have a lot of spare reading time
The brp website shows two tubes around the framerail if It matters, so its hard to say for sure. Just read in another s10 forum that one went around, false knowledge is dangerous, lol.
I have seen some guys getting away with the 8.5inch 10 bolt from the zr2's, may could find one cheap, some of the codes
RPO codes:
GT4-3.73 gear ratio
GT5-4.10 gear ratio
GU4-3.08 gear ratio
GU6-3.42 gear ratio
G80- Positraction, Limited Slip
LB4- 4.3 V6 TBI
LN2- 2.2l 4cyl MFI
LU3- 4.3 V6
L35- 4.3 V6 CPI
M30- Auto 4 SPD trans
M50- Man 5 SPD trans
S10 Pickups
1995 s10 2wd 8.5 rear, (LB4,L35,M30,GU6)
1995-1997 s10 2wd 8.5 rear, (LN2,M30,GT5)
1996-1999 s10 2wd 8.5 rear, (L35,M50,GU4,G80)
2000-2002 s10 2wd 8.5 rear, (M50,GU4,G80)
2003 s10 2wd 8.5 rear, (LU3,M50,GU4,G80)
S10 Blazers
1995-1997 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
1998-1999 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
2000-2001 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
2001-2004 s10 blazer 2wd 8.5 rear, (M50,GU6,G80)
2003-2005 s10 blazer 2wd 8.5 rear, (M50,GU6)
Old Nov 20, 2013 | 03:30 AM
  #36
ZONES89RS's Avatar
In-Zane Moderator
Probably be easier finding a explorer rear for super cheap with 4.10s. And 94 up is all disc brakes. The wider explorer rear may be the way to go so I can run 93-02 f body wheels on the rear without spacers.
Old Nov 20, 2013 | 03:24 PM
  #37
snook's Avatar
I chatted with the small window at pace performance, said they were out of stock, but could get them in 2 weeks, then ship out for 65 bucks. They asked why my IP dint match a texas account, lol
The explorers are plentiful around here too, so that's probably your best bet. I need to find one for mine
Old Nov 20, 2013 | 03:44 PM
  #38
ZONES89RS's Avatar
In-Zane Moderator
Yea, where you located?
I'm waiting till my money gets here to go ahead and make things happen.
Old Nov 20, 2013 | 04:04 PM
  #39
snook's Avatar
Tennessee, lol Last time I went to the pick a part there was 5 of them
Old Nov 20, 2013 | 04:09 PM
  #40
newschool72's Avatar
A friend of mine did the 8.8 swap. He got two of one side on the axles and had the one side cut down. As far as I know, it all worked out great.
