Beater build s10
I made some caltracs for my s15. I can get some pics if anyones interested.
I used 1" .090 wall chromoly with 3/8 plate that went through the leaf spring bolts and welded to the axle bottom mount under the leaf. I turned down some shaft and drilled and tapped it and slid it inside the chromoly then welded it up. They look great and work awesome so far!
sorry to hijack a bit here but I can get some pics tomorrow for people...
Yup, I'm going to have to tune some more, didn't do that on the dyno so clearly the placement of the o2 or real world driving are not on line with the dyno tune. Maybe it will be better when I put the air cleaner on for all I know.
Don't need any tips, I need track time. Bastards screwed my night up good.
Anyway, here is a video of running through the gears. Took a friend for a ride and figured I would record it:
http://youtu.be/BGWsh9ADQzQ
In search of a 15x8 with a 6.5 back spacing for the rear right now as well.
Yup, I know I can go to a 17 inch wheel, that will probably fit perfect, but I will need to have these axles drilled, or new axles. Either way that's a bunch of money I'm not going to spend on this thing any time soon. The mustang needs me to set some cash aside.
what exactly are you trying to do?
here, a 15x9 at 7.5 bs should completely tuck a 1st gen on a 275/60-15 on a full width 8.8 rear end.
http://www.summitracing.com/search/p...rder=Ascending
Ive got a full width + c clip eliminators explorer 8.8 so it adds roughly 2 inches to the width. I just bolted it in tonight and im going to run 15x10 with 7.25 bs race stars with a 325/50/15 tire. The tire will stick out 3" from the bed to the edge of the sidewall! I wanted a 15x10 8.5 bs but they dont make it. Fyi 15x10 7.25 bs still has about 3" room between the rim and bump stop.
everyone said the rear would only be roughly 3" wider so I ordered 4.5 bs and wow they are horrible!
I would think that is because of the disc brake package. The drum brake setup (so I have read) only requires a short side axle and 3 inch narrowing of the long side and it is the same width as the stock s-10 rear end. You have to change spring pad locations as well if I understood right.
Mine ended up about 9" wider overall than my stock rear end! I think I was confused by the measurements given for a 4x4 s10 because they are wider rears than a 2wd?
