Beater build s10
#463
The way the bars are set, with the back "up" should make for a light hit on the tires. What did you weld the front bracket to? It will have to take a he!! of a lot of pressure! LOL. As long as the metal you mounted it to is strong, they should work very well. From what Ive been studying , the lower the back/higher the front, the harder the hit on the tires and visa versa .
Im bailing on the construction thing. Without a welder its not worth it. Im working with a guy on a deal for a set of Slide-a-Links now. Zane, the gorilla weld bars look good . Be sure to shoot a vid of them in action!
#465
The front mounts are welded to the bottom of the bracket where the front of the leaf spring bolts to its perch. I personally would want them a bit longer to reach the frame rail just past there. maybe 6-9 inches past.
Don't have a hissy about the track crew, and you didn't call Stu to tell him you were going...
#466
Stewart and I are members if another forum where he knew I was going to the track, so if he forgot, that's on him.
Do yours how you want, it's your truck. I made my as a solution to eliminate wheel hop and it is working the way I wanted.
#467
I know about the other forum, remember?? I am a member there as well?
And I only said something because he texted me a reply back about the voltages for his S-10. He said you hadn't called him.
And yes, I know its personal opinion on the mounting points. I was merely stating that I would have made them a bit longer. Nothing bad about yours intended.
Did you get a chance for a time yet? how did it do?
#468
Ed, I'm pretty pissed. Sorry. Made one pass and loaded it up because every moron and their mom showed up at the track. I got skipped getting in and then skipped in line when I was number 5 in my lane. Was there 2 hours to make one pass and I spun to a 2.3 60 foot and went 8.9 at 84 mph.
So, maybe next time. I'm not happy I busted *** to finish the ghettotracs just to waste my damn night because people are morons.
#469
yikes... the 60 ft sucked but the 8.9 with a 4.8 is decent. yeah it has a lot more in it knowing your builds, but at least it didn't wheel hop and break the traction bar setup...
All in time. You will have plenty more chances during the summer to get it into the 7's knowing you. I would be thrilled if my S-10 belted an 8.9 on motor..
#473
Or I'll just lower the pressure and make the MT drag radials work better. Then throw the 26x10.5s on the back and know it will work or break the ghetto tracs.
#474
#477
this is all true for a traditional cal-trac setup. what zane built is a long bar setup which works amazing for lightning guys. with no pivot on the front spring eye, there is no "hit." long bars are only there to control the pinion which will stop wheel hop. I don't think the angle of the bar matters on long bar setups, but I do think the length of the long bar can change things.
#478
Drop pressure to 20, heat em up again and let it rip for another round.
#479
Don't need any tips, I need track time. Bastards screwed my night up good.
Anyway, here is a video of running through the gears. Took a friend for a ride and figured I would record it:
