Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Beater build s10
Old 03-31-2014, 07:44 AM
  #521
In-Zane Moderator
ZONES89RS's Avatar
That's called slipping the clutch. It is all I could do to break out of a 2.0 60 foot, everything else would launch and then unload the rear tires. Which is aggravating. And all my shifts hit the rev limiter, I hold the gas to the floor. That pass was a hot lap, and the master being so close to the header is not exactly friendly, it is causing the shifter to be forced I to gear after abusing the truck. As I expected it would. Need to wrap the header.
Old 03-31-2014, 08:56 AM
  #522
newschool72's Avatar
That's not bad at all, Zane. I just did the Wallace calculator and that's a 13.0 to 13.10 in the 1/4. An easy 12 sec truck with traction .
Old 03-31-2014, 10:22 AM
  #523
In-Zane Moderator
ZONES89RS's Avatar
Yea, that's exactly what I was thinking. Not sure if I am dead set in locking in a better ET. Maybe if I get a wild hair I might try. For now I'm satisfied. I wanted to think it was on my 5.3 TAs heals, not too far off. But the extra cubes of the TA shines. It traps 91 or 92 and went 7.7 with no tuning compared to the 4.8 truck.
Old 03-31-2014, 05:51 PM
  #524
BigEd_72455's Avatar
Well, you put this thing together for fuel mileage not ball blasting runs.... Now drive it like a granny and report back some fuel mileage results...
Old 03-31-2014, 06:24 PM
  #525
In-Zane Moderator
ZONES89RS's Avatar
That's the plan. Just leaned out idle and primary jetting. Still need to use the wire trick for the low speed bleeds.
Old 03-31-2014, 06:26 PM
  #526
krochus's Avatar
Lol what wire trick would that be ;-)
Old 03-31-2014, 09:14 PM
  #527
In-Zane Moderator
ZONES89RS's Avatar
Not that you would have a clue, lol.
Old 04-01-2014, 07:58 PM
  #528
Got more done today!!
Old 04-02-2014, 07:14 PM
  #529
EastTnZ28's Avatar
Thats awesome. Now you got a trash hauler that will bust 90% of the cars on the roads ***. Well done!!! Quickly done too.
Old 04-02-2014, 08:44 PM
  #530
In-Zane Moderator
ZONES89RS's Avatar
Thanks man, it is faster than I expected it to be, but I'm surprised it doesn't trap faster. If it would run a 7.9 with a 1.6 60 and trap 84, it would be strange. My TA hit 7.7 at 91, but was a 1.77 60.
Old 04-02-2014, 09:05 PM
  #531
EastTnZ28's Avatar
I thought it would trap faster also. Im like you. I bet alot of it is in the 60'. Still killer though. I keep forgetting its a 4.8.
Old 04-03-2014, 03:24 AM
  #532
In-Zane Moderator
ZONES89RS's Avatar
Yea, I'll keep an eye out for some shocks, but I'm geared towards getting a 4l80 for the mustang right now.
Old 04-03-2014, 09:07 AM
  #533
EastTnZ28's Avatar
Are you gonna rebuild the 4l80 before you use it if its good? I have a stock one with 90,000 miles that im gonna use. It works good but im hoping my new motor will be 500hp and im wondering how long it would live with a 3500 stall.
Old 04-03-2014, 11:37 AM
  #534
89gmcs15's Avatar
That thing runs pretty good for a 4.8 tho! Surprise a few vehicles out there if theyre not expectin it
Old 04-03-2014, 12:12 PM
  #535
In-Zane Moderator
ZONES89RS's Avatar
Already surprised a couple, lol.
No, I may do a shift kit because they are cheap. My 198k mile 4L80 in my 86 TA is running fine behind the cammed 5.3 liter. Doesn't skip a beat and it is probably a touch over 400hp.
Old 04-03-2014, 07:07 PM
  #536
EastTnZ28's Avatar
Cool. Im gonna do the same and see how long it lives. Ive just read that some of the controllers dont work perfect with a worn tranny. What controller are you thinking of using or are you gonna go manual valve body? They aint cheap either.
Old 04-03-2014, 07:09 PM
  #537
TX Silverado uses the EZTCU unit with his and he has had no complaints out of it once he finally got it tuned how he liked it.
Old 04-03-2014, 07:11 PM
  #538
EastTnZ28's Avatar
I was debating that unit or the FAST. Knowing my cheap *** it'll be which ever one is cheaper. Ive read positive things on both.
Old 04-03-2014, 07:47 PM
  #539
In-Zane Moderator
ZONES89RS's Avatar
For the mustang I'll be using a jakes controller that makes you shift manually but keeps the line pressure where it needs to be.
My TA and 94 solid breads used the FAST EZ TCU. Works fantastic on both, even the 198 k mile 80.
Txsilverado is using the older piece not the new one you can tune yourself like I have. Mine will control a 60,65,70,80,85 and a TCI 6 speed auto and all the changes done with the handheld that come with it.
Old 04-03-2014, 07:59 PM
  #540
EastTnZ28's Avatar
So with the Jakes its gonna go into whatever gear you put it in no matter what rpm. So if your in 4th gear at a red light, its in 4th gear when you try to pull out, right?
Quick Reply: Beater build s10
