MSD startup problems
Is there a difference in the crank sensors between the old and newer motors? Is the 24 tooth sensor different than the 58 tooth. If so is my 6010 box compatible to both?
My 6.0 fired right off but this new one is giving me h**l.
I think I read that there are different sensors for cam and crank for early and later model motors. Just wondering if I have the wrong sensors and that they may not be compatible with my box.
I made extensions wires for the relocation of the cam to the front of the new motor. Double checked those to assure I didn't mess up.
I also thought I might have the wrong timing set. Is there any way to check this without removing all the front accessories and covers? Is there a way to check to assure the sensorf is picking up a signal off the timing sprocket?
The timing chain set cam gear should have a raised pad on the front to trigger the cam sensor. Some have one large raised others have multiple raised pads. If your cam gear has a bunch of holes with no raised pad then you have the wrong gear for the front mount cam sensor.
http://www.daytona-sensors.com/SmartSpark.html
It looks to be way more advanced than what MSD is offering for LS engines.
Could you please verify the date of the engine.
Correct me if I'm wrong. It sounds like you have a Gen 1V block with a 24 tooth reluctor on the crank.
Gen 4 blocks did not have a cam sensor spot on rear of the block (thus the front cam sensor) and the oil pressure sender will be on the valley cover.
If that is the scenario, it actually changes your question IMO. Your question should be whether a 24 tooth crankshaft can be retrofitted to the gen 4 block.
24 tooth reluctor will need a 24 tooth sensor. As stated if the cam sensor fail code comes on and it only fires half the time. Then you probably need to switch the two outside wires around on the 3 plug cam sensor connector.
But for what it's worth here's a summary of my troubleshooting efforts:
1. Checked with shortblock builder to verify a 24 tooth reluctor was indeed installed. It was verified. Checked for proper crank sensor. It was correct.
2. Removed cam sensor and checked cam sprocket to assure it was a 1X. It was.
3. Called MSD. They gave me instructions that included splicing in the MAP sensor Orange wire to the pink sensor wire and 1K resistor across the two outside sensor wires. This was not a successful fix. Motor refused to fire at all.
4. Called Don Hardy and he gave me instructions to swap the two outside sensor wires. Motor fired right up.
At this point I'm going to remove the MSD "fix" and re-attach the standard pink wires and test with just the outside wire swap.
Thanks for all the inputs and assistance.
