Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Q&A session here.....
Old Dec 3, 2016 | 07:15 AM
BigEd_72455's Avatar
Default Q&A session here.....
I have a couple questions to ask before I jump into what all I am doing and then asking for recommendations for cam and carb..
bit of info: 91 excab S10, TH400 (no transbrake at this time), 4500 nitrous converter, 4.30 gears, 29.5/11.5-15 rear tires. This truck will ONLY be raced 1/8th mile.
1). I got ahold of a 6.0 IV iron block yesterday with 0821 heads. Which engine is this actually designated as? It has the flat lifter valley plate with a small notch at the back on one side, and the oil pressure sensor is mounted in the plate.
2). Can I buy a billet flat plate to cover the oil sensor hole and the 8 risers under the plate and it not bother anything? I have a muscle car swap pan I am going to install and the oil pressure sender for my race project is mounted above the oil filter.
3). This truck is strictly for drag racing so what cam do you guys recommend? I do plan to run nitrous and a Dominator intake and carb. I want something that is choppy idle and will run to 7000 rpm with over 600 lift.
i am going to install comp 3/8 hardened pushrods and trunion upgrade, and Brian Tooley .660 double springs.
4). Do I need to upgrade the rod bolts as well?
5). Which VVT delete kit do you guys recommend? I am going to install a new timing chain and gears so do I really need to go to a double? Any clearance issues I need to worry about doing that?
thanks to all who answer and please keep it civil.
i don't mind recommendations or other questions about the project.
Old Dec 3, 2016 | 03:42 PM
Doug G's Avatar
1) LY6
2)yes, I believe so, but why move the sending unit hole ? You can install an adapter then use a mechanical gauge.
3) ???
4) Its is recommended.
5)haven't done so unsure
Old Dec 3, 2016 | 04:22 PM
1). Thanks. I figured out which one it was a little while ago.
2). I am moving the sender because I already have a muscle car swap pan, and the sender for my digital gauge is right above the filter on the pan. And I am going carb.
3) I have a couple options for the camshaft selection.
Old Dec 3, 2016 | 05:15 PM
Doug G's Avatar
Just a heads-up.... the Muscle car pan will hang about 2" lower than a standard SBC pan in the same application. Most go with the Holley pan.
Holley pan,
Old Dec 3, 2016 | 05:19 PM
I am very familiar. This is my 3rd S10 project and I may be getting a second gen S10 in the next couple months. Something else to spend more money on.
Old Dec 4, 2016 | 04:40 AM
Doug G's Avatar
Very good, just didn't want to see another "oil pan too low" thread
As for the cam...I've never build a nitrous only motor, so not of much (any) help.
Old Dec 4, 2016 | 05:10 AM
Only part of the pan that hangs below the crossmember on the S-10 is where the drain plug is. And that could be remedied with simply moving the plug to the back.
but that issue varies by which mounts are used.
Old Dec 5, 2016 | 10:52 AM
speedtigger's Avatar
Old School Heavy
Originally Posted by BigEd_72455
1). I got ahold of a 6.0 IV iron block yesterday with 0821 heads. Which engine is this actually designated as? It has the flat lifter valley plate with a small notch at the back on one side, and the oil pressure sensor is mounted in the plate..
Probably an LY6
Are you going to run the stock shortblock or build the engine? This is important on camshaft selection as we need to take piston-to-valve clearance into consideration.
Many people including myself have exceeded 7000 RPM on a regular basis with gen 4 engines with great reliability.
As I understand, the LY6 have VVT but does not have DOD to worry about. If I am correct, you can use this kit: http://store.cammotion.com/catalog/p...d84d23164c3354
Old Dec 5, 2016 | 12:11 PM
Dropped the block crank and heads off at the machine shop a little bit ago. One of the guys noticed right off that 2 of the seats were loose and 1 guide had dropped.
They told me the valve job by itself was over $200 plus cleaning them was between 40 and 70.
So I figure getting them fixed will cost way more than what I can just buy another set of heads for.
Hopefully the crank can be polished and not have to be turned. Block is only going to get cleaned up. And I have the rods and pistons here still.
Right now for just the block and crank (polishing only) I am looking at $110+ whatever the tax is.
The heads are what's going to be the brain stumper. Do I spend the money to get those done or just buy another set is what becomes the dilemma.
Old Dec 5, 2016 | 12:35 PM
Old School Heavy
What is the total price to fix them, do a good performance valve job and ready to bolt on?
Old Dec 5, 2016 | 12:54 PM
I just dropped them off. And the head guy is gonna be gone to the PRI show for the second half of this week.
They said 3 angle valve job, deck the heads, and clean them, not counting the seats and guide(s) was already at $310-325. Now, I get these are good heads to have because of the big valves and rectangle ports, but I just can't afford to go all whole hog with them and spend $1000+. I just don't have the money available even with paying payments to pay them off before getting them, I am spending $20 in gas to and from just to make the payment. I'll know more about what's happening with them in a week to 2 weeks..
Old Dec 5, 2016 | 12:56 PM
Plus, I am more concerned with the block than the heads right now. If all else fails I can just go get a pair of 862's or 317's and run them until I decide what to do with the 0821's.
Old Dec 5, 2016 | 02:47 PM
Doug G's Avatar
New stock LS3/L92 heads will be $1000+
Used LS3/L92 heads will need to be looked over/fixed/ETC before use anyway IMO....
fix yours
Old Dec 5, 2016 | 03:16 PM
Old School Heavy
I think a used pair goes for about $600.
Old Dec 5, 2016 | 03:42 PM
baronsmith98's Avatar
I'd stick with your square ports and fix them. If you go to 317s you will have to get a different intake and rockers
Old Dec 5, 2016 | 04:01 PM
the rockers have nothing to do with what intake I run...
those are are under the valve covers and only open and close the valves.
Old Dec 5, 2016 | 04:02 PM
And if I buy heads, they will have rockers with them. If not, I already have a set of the straight ones.
Old Dec 5, 2016 | 06:02 PM
You just said you were thinking about running a set of 317s then possibly going back to the square ports. You would have to get DIFFERENT rockers for the heads and a DIFFERENT intake because of the cathedral/square port difference. Good luck with the build
Old Dec 5, 2016 | 06:09 PM
and as I said above, if I bought heads, they would already have the rockers with them.
I Know the difference in square port vs rectangle port vs cathedral port.
But thank you for reminding me about the changes that would have to be made.
Old Dec 14, 2016 | 11:58 AM
fast89stang's Avatar
I would fix the heads, you might install new rod bolts, but I didn't. Doesn't mean that's right, but I have turned mine to 7500 ALOT. I would contact the cam grinder of choice for cam. The rectangle ports are more critical of cam choice. Talk to Trent about the cam, he knows a thing or 2. Also, speak with him on dominator. My LY6 didn't like one. Not saying it wont work, but didn't on my combo. the shift recovery sucked.
