98-02 guys, how do you do it?
I just spent my morning trying to do something simple.. swap coils on my ls1 in my 2000 z28.
After tooling around, cursing a lot, cutting my hands up..I come across a bracket on the back of the motor on the DRIVER side I can't get loose.. and I know the passenger side is gonna be 100 times worse.
I'm curious guys.. how do you work on these cars?? Mine needs a lot of engine work and I'm not really fond of paying a mechanic to do it all when I know HOW to do it..I just can't reach anything!![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
any tips/tricks? I WANT to get into the valve cover on the driver side.. got a clanging/rattling in there that I want to look at. I don't have any replacement parts handy, but I could at least see how bad it is.
My car has full emissions so that's 3/4 of my problem.. tubes pipes solenoids everywhere.. I can't remove em until the car is 25 years old.
so not an option to LEAVE them off.. and I'm not terribly fond of taking them off every time I need to do something simple.
Right about now I'm wishing I had a sport truck instead of an Fbody..
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
1 Post
Take the coils off w/ its bracket but when u put back on put only the 3 center ones on so u dont have to get the back ones off again and the 3 will hold fine and if u need parts u can find them on here cheap !!!!!
I mean in general, how do people work on these cars.I mean do they just take things off that are in the way every single time? I couldn't get the driver's side coil bracket off because of the EGR bracket. It's on top of the bolt and bolts to the BACK OF THE HEAD. I can't even hardly get my hand back there.
Can I pass emissions without all this nonsense? I mean I'll have to have the ECU tuned to turn the CEL off.. but will my smog numbers change? It's worth it to me.. I really can't afford to be putting hundreds down every time something simple needs to be done to this car. I should be able to do most everything external to the engine. 99% of the CEL problems I've had since I got the car was air pump, EGR check valves etc.
You just have to learn man. There is always an easier way to do something on these cars, you just don't figure that out until after you've done it the hard way. All the sudden you get the "Oh man, if I just moved that...." or "Crap, this moves out of the way if I do this" kind of feeling and then you get a little pissed, haha! But next time you'll know what to do and then you don't think it's so bad. Like others have said, leave some of the bolts out for next time. I only have four bolts per side so I can just pop them out if I need to. For good practice you can help your friends work on their F-Bodies and you'll learn lots of valuable information for when you have to do the work on yours.
Hang in there 'OP, you'll get it...
Lol yeah my first spark plug change took me 6hrs then got it down to 1hr on a stock motor. Now since i have deleted my emissions i can change them out in as little as 30 min.. Yup
I had 3 LT1 cars before I had my current LS1 car. The LS1's are a walk in the park to work on compared to the LT1's. Plus now that I no longer have A/C, EGR and AIR it even easier. I took my coil packs off the other day in about 10 minutes and can change all the plugs and wires in about 20 minutes. One thing you can do to make getting your coil packs off easier is replace the bolts that hold the brackets to the valve covers with allen head bolts. Maybe it's just me but I find them much easier to get out in the tight spots.
