402ci/9in/Nitrous build - 02 Camaro Z28
Hey guys figured i'd might as well start another build thread on the slomaro. Lilttle backstory here...bought the car in February of '13 bone stock and within a year I have done everything that's stated in my signature. Decided to get a "little" more involved with the car and I went a little overboard. I ended up getting a LS2 stroked to 402ci from Texas Speed about a month ago, bought a Mcleod RXT/flywheel from Hinson Motorsports, and yesterday I bought a 9in (35spline/wavetrac) from Speed Inc. I plan on running nitrous on the car as well so this should get good. I plan on running the car mostly on the street and i'll be on the track maybe twice a year. If anyone has any tips and tricks to anything that might come my way please share!
I ended up starting the teardown a few days ago and it has been a lot of work to say the least. There was a thread on here showing everything to do when removing the engine/trans so that helped a lot. Once everything was disconnected I ended up taking the motor/trans out through the bottom which wasn't too bad. After it was out I took I had to swap all the accessories over to the new engine and everything else that comes with putting together a long block since it was pretty much a long block. There was a couple things that was still needed like new harmonic balancer since I have key slot (ordered the ATI super dampener), needle bearing, and injector spacers. Put the Mcleod RXT in and attached the trans back to the motor. Just need how i'm going to do my vent lines, then i'll be putting it back in.
Here's a video when I first got her started over a month ago.
Today I just installed MSD coil pack plugs to replace the OEM ones the came with the car when it was new.
