questions about my 95 z28
dumb question
ok well im a pretty new lt1 newcomer and i just bought a 95 z28 and my speedometer only goes to 110 mph some people tell me because it didnt come with "z' rated tires from the factory its like that.Now someone is tellin me i dont have a real lt1 in my car i just want to clear this up because from what i understand all z28's from 93-97 came with a lt1 the same engine in the vette,is this true?.Also can someone give me another explanation for my 110mph speedo if what i think is not true.Im just confused and want to clear this mess up.
Thanks,
Chris
Thanks,
Chris
dont worry you r not the only one with that question a couple of my friend have the same question the answer is hard to answer maybe yeah about the z rated tires but the car is a Z28 rare but is is ? does your car have 1, on your shift **** like 1,2,
Thanks,
Chris
Thanks,
Chris
My Firebird came with a 150mph speedo, but it still has the limiter for not having the Z-rated tires so i dunno.
The engines are baslically corvette engines, except for a different intake and exhaust style. Also the fuel rail covers. Maybe the cam specs.
If your auto goes PRND32 then you have 2.73 rear end gears which was most often the option without the Z rated tires. Its what i have. They only ommited the 1st gear downshift because it wouldnt pass the noise deceleration in 1st gear. If you remove the top of the console you can get to the little plastic piece and cut it off. I did it with a hacksaw blade in about 3 minutes while i was waiting for my car to warm up.
Vettes had 4 bolt mains, ours only have 2 bolt mains. There are other differences making the power output differences. Its not the same as a vette engine though, I hate when people walk around saying its the same as a vette.
Alot I'm not sure of concerning the speedos and tire ratings, but as for the engine crisis, If it is a V8 and it's got some *****. it's a LT1, not a transplanted L99 and I'm sure you could tell the diff it's a V6. As for the difference in the F-body and vette LT1's is the cam specs. It was only a mere 10 hp difference but the same heads, intake, 24# injectors, etc. All vettes had 4 bolt mains though and very few F-bodies, usually late in the year builds, got a 4 bolt main block due to shortage of 2 bolt blocks.
Metalbeast, your SS should be a 4bolt main.
