can ls1 f-bodies be 'numbers matching'?
On a 98+ f-body do they have a build sheet? Can you have a #s matching block? do the heads and tranny have a casting # you can verify with a build sheet or vin? I know how the old cars work but the new ones i have no clue.
Well, some people have said that the VIN is etched into the passenger side of the block and/or the engine serial number should match the VIN:
https://ls1tech.com/forums/conversions-swaps/274851-help-identify-ls1.html
https://ls1tech.com/forums/conversions-swaps/187205-what-determines-year-motor-ca.html
https://ls1tech.com/forums/conversions-swaps/278270-couple-swap-questions.html
Thanks, I read those. So apparently you match the block to a vin. But thats it, no casting #s on heads or anything. Is there a build sheet thingy that has the info on it? I dont think there is.
