different engine mounts
Old 05-26-2009, 11:13 AM
millwright1999's Avatar
Default different engine mounts
I have been reading alot on here about different engine mounts, that some move the engine forward and, or up from the original gen I small block location. Can anybody tell me which mounts from what company are good to use and how much they move the engine?
Old 05-26-2009, 11:21 AM
Former Vendor
SBROliver's Avatar
I am also interested in what mounts would be best for my C10 2wd
Oliver
Old 05-26-2009, 01:35 PM
LS1GMCTruck's Avatar
I believe the flat plate engine mount "adapter" plates, are pretty much all the same. Some people simply flip them from side to side of the engine, which changes the bolt pattern a bit in placement, front to back. Its just up to you where you choose to place the engine, a little forward...or a little back. This sometimes makes it easier to place your transmission mount as well. Good luck.
Old 05-26-2009, 02:03 PM
Oscar Will's Avatar
One mount configuration that is often overlooked is the Corvette style mounts. They won't fit alot of applications but in my case (an old car with a boxed front crossmember) they work excellent. Those oil filled cushions really isolate the engine from the chassis and provide a very solid engine mount as well.
Old 05-26-2009, 02:16 PM
fast's Avatar
varies by vehicle
plenty of good companies making swap parts
don't leave oil pan off your list of considerations on engine placement
Old 03-13-2010, 03:30 PM
What mounts, headers and oil pan did you use in your Camaro?
Old 03-13-2010, 03:31 PM
Originally Posted by fast
varies by vehicle
Old 03-14-2010, 12:08 AM
Monte4ever's Avatar
I was going to use Spohn LS1 frame mounts for my 82 Monte along with their poly bushings and stock clam shells. However, when I tried to sit my motor in place it would not line up on one side. They were off almost an half inch. I ended up getting Edelbrock's engine plate's (#6701), and Moroso's frame and engine mounts (62515 - 62630). I sill had to enlongate a few holes slightly but it when in perfectly afterwards.
Old 03-14-2010, 01:12 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Not all of the plate mounts are the same. I can't speak for all of them, but I know that the Edelbrock mounts place the engine in exactly the same location as a SBC/BBC.
Andrew
Old 03-14-2010, 05:04 PM
Monte4ever's Avatar
Andrew
I can vouch for that.
Old 03-14-2010, 06:47 PM
Monte_LS3's Avatar
Default Swap parts for X-body
This search might help:
http://www.google.com/search?hl=en&t...i=&safe=images
Old 03-15-2010, 09:55 AM
gmbtahoe's Avatar
I'm going through the same problem as we speak. I've seen 2 different types. One type shares the bottom hole of the original SBC with one of the LS, the other has the lower SBC hole about 1 inch forward and about 1/4 inch lower. I'm not sure why there is a difference. The kind I needed turned out to be the offset version. Trans Dapt sells several different type, I'm getting mine from Advance Adapters.
Old 03-26-2010, 07:16 PM
found some info on mounts here
http://firstgens.com/phpbb/viewtopic.php?f=16&t=317
I found this, it may help you out.
Quick Reply: different engine mounts
