power steering pump lines
Old 07-11-2010, 07:47 PM
crosstraining's Avatar
Default power steering pump lines
I have 2006 LQ9. The power steering pump has 3 lines. 1 high pressure & 1 return. What is the 3rd line? Is it for the hydroboost? Can I just cap it? If so, how do I cap it?
Thanks
Old 07-11-2010, 08:23 PM
Jimbo1367's Avatar
I believe you are correct. Hydroboost. I think people do just cap them. Try a " SEARCH" its been discussed MANY times before. Sorry I couldn't help more.
Jim
Old 07-12-2010, 12:15 AM
Jim_PA's Avatar
If you arne't already aware... you can un-thread the pressure line fitting, and thread in the one from your nova's power steering pump. It worked on my truck anyway! This helps so you don't need to have a custom line built.
Old 07-12-2010, 04:48 PM
How do you cap it off???
Is it something you buy or can you weld it shut?
I have not had much luck with the "search" button.
Old 07-12-2010, 05:03 PM
Pocket's Avatar
Use any sort of oil safe rubber cap. The return side is not pressurized
Old 07-12-2010, 06:45 PM
I thought I needed to cap 1 of high pressure sides?? The 1 that went to the hydroboost. There are 2 coming out of the bottom. I was assuming it was 1 of those.
Old 07-12-2010, 07:00 PM
Krom's Avatar
that picture shows 1 high pressure line, and 2 low pressure lines (thin hose held on by spring clamps)
Old 07-27-2010, 04:22 PM
hookemdevils22's Avatar
i capped that upper line with a standard rubber cap and a hose clamp. it didn't last long - puked everywhere the other day. now i'm trying to figure out a higher-strength solution to my problem aside from welding the damn thing shut. let me know what you find.
Old 07-27-2010, 04:44 PM
-TheBandit-'s Avatar
Can anyone else verify this statement?
Old 07-27-2010, 07:47 PM
Hookemdevils22, I asked Frojoe what he suggested. Here is his response, and it is what I am doing:
Yes my PS pump had three ports: a metric fitting on the bottom for high-pressure, and two 3/8" hose ports on the side for return, originally meant for one from the steering rack and the other from the hydroboost. I originally used one for return from the steering box and then blocked the other one off by hose clamping a 2-inch long bit of 3/8" hose with a 3/8" bolt in the end of it, with a hose clamp clamping the hose to the bolt threads. I've since decided to include hydroboost so all the ports will be used up.
Cheers,
Joe
Old 07-27-2010, 09:00 PM
Pocket's Avatar
You could simply replace the pump. The old style pumps arent exactly hard to find
Old 07-28-2010, 07:02 AM
Klimaxx's Avatar
its true..
Old 07-28-2010, 12:19 PM
Needs to finish car
Chris442's Avatar
You could just pick up a pump from a 1/2 ton truck, which wouldn't have the hydroboost port on top. You could also pick up just a reservoir, and swap the pump over.
Old 07-28-2010, 01:05 PM
yeah, the best route would be picking up a non-hydroboost pump. but i'm not exactly excited about replacing the pump right meow.
Old 08-10-2010, 01:12 PM
chevydog66's Avatar
I haven't fired mine up yet but I do need to cap off the 3rd line. I was thinking about threading it with a tap, screwing a bolt in and use some thread sealer. My 6.0 is already in my 72 GMC truck so I don't want to borrow the pulley tool and switch pumps. What do you think?
Old 08-19-2010, 05:28 PM
give it a shot and report back. my only reservation would be contamination from the tapping process.
Old 08-19-2010, 08:57 PM
chevydog66's Avatar
I plan on putting a bunch of grease on the tap so that the shavings stick to it. I just need to find out what size hole it is and what size tap I need. Probably do it tomorrow.
Old 09-26-2010, 09:17 PM
chuckd71's Avatar
Any luck? What size tap did you use?
thanks
Edit: never mind
https://ls1tech.com/forums/conversio...t-cap-off.html
Old 09-26-2010, 09:22 PM
chevydog66's Avatar
Yep, worked great, still no leaks.
Quick Reply: power steering pump lines
