S10 Xtreme L33 swap!
So getting ready to start my first LS swap and figured I would start a project thread. So here's the patient...
And here's a link to my other build thread in the member's projects section on S10 forum if people want to see what has been done to the truck so far: http://www.s10forum.com/forum/f30/pr...xtreme-430592/
And here's what came in today
L33 with 29k miles and a 4L60e with 40k miles on it
Other part's on the way:
- 98-99 F-Body manifolds
- Superior aluminum S10 V8 swap radiator
- Dorman 300-201 power steering pump pulley
And some other part's I've pulled so far from the junkyard...
- Blazer auto console
- Cable driven throttle body
- engine cover
- 4.3 throttle cable
- engine cover
Well, I'm home for summer now, thank god! Unwrapped the engine to check it out, some pics...
799 Heads
Anyone know what this is? Looks to be broken off...
Superior Performance swap radiator...
Dorman PS pump pulley...
799 Heads
dont worry about the broken part, it's a super easy to replace - if you're using a hydroboost setup on your s10 just buy a new plug for it if this one isn't sealing - if you're using a traditional brake boost you will need to run your vacuum line to this location(i personally used a plug that i drilled through and epoxied a 90degree barb to - then pushed the vacuum hose onto that)
to remove the broken plug, push back the red part with your nail, hold it back and just slip out the plug (water coolers and some refrigerators use this same type connectors for their waterlines)
Thanks!
Some progress made today, got the engine onto an engine stand and pulled the wiring, exhaust manifolds, and some other junk off.
pulled the DBW throttle body off and cleaned up the DBC cable I pulled at the junkyard and went to put it one where I ran into my first issue...
Can that vacuum connection on the intake manifold be removed and replaced with some sort of plug or do I need a different throttle body? Or a different intake manifold?
Any one need a wiring harness and PCM for a DBW swap? I'll be posting it in the classifieds here soon.
fixed the throttle body issue...
Pulled the valve covers off to clean them up today, motor looks clean on the inside!
Anybody wanna guess what this 4L60e is out of? Cause I don't know...
Motor all cleaned up...
Shattered my new PS pump pulley putting it on
New one on the way already, was my own stupid fault. Was using a bolt and a socket to pull the pulley onto the shaft of the pump, had the socket resting on the plastic part of the pulley rather than the metal part, impact gun caused it to shatter. Live and learn.
Ordered my wiring harness and ECM/programming from CPW today! Also thinking about smoothing the truck intake, any thoughts on that?
Did some digging, the code on the sticker on the trans is 9LHD which turns out to be a 1999 GMC VAN G2500 5.7 Cyl 4L60E
Correct me if I'm wrong but that's a non LS motor, will this still bolt up to my L33 properly?
yes it will bolt up but IIRC you will need the spacer for the Torque Converter spud.
The electronics might be different too. Not sure. I think S&P has a writeup on how to make it work.
Sold off the auto trans in search of a T56, had a lead on one but it was bought out from under me, so the hunt continues. Not much going on in terms of progress, waiting on my wiring harness. Motor mounts are on the way, may hit the junkyard later today, I'll be sure to post up with any scores!
Nice truck. I will be subscribing to this post. I have an S10 with a 4.3 that I'd like to do a swap in. I really like that radiator.
BTW, I have the same blazer style console and shifter as you have in the pics. Plan on installing that over the holiday weekend. Already have blazer seats in the truck.
You should check the throttle body to manifold mating surfaces. I found I had to fill the back of the TB with silicone for the vent tubes. It would have caused a serious vaccuum leak. I put a DBW TB on a 99 LS1 intake. The vent on the truck intake goed through a small hole in the TB and gets air before the TB blade. Cable TH gets vent through the port you plugged. Just some info for you to double check.
I hadn't thought of that, I'll have to double check that, thanks!
Nice! The radiator is a pretty slick deal, and a good alternative to the $500 CPW radiator that doesn't have a built in trans cooler. It's a direct fit for the first gens, and will fit in second generation S10's core supports with some trimming in the corners on the core support.
Small update...went to the junkyard the other day and grabbed some small stuff, couple bolts, radiator cap, upper radiator hose from a 5.3 silverado (for test fitting), and the brake booster nipple that was broken on my intake. Also pulled some threaded inserts out of an intake for my intake manifold since the L33's came DBW and I'm going DBC.
Pressed them in...
Got my 98-99 F-Body manifolds I bought off of blackphantom (excellent seller by the way, very fast shipping!)
Pressed them in...
