Speartech GEN-5 LT1 Stand Alone Control System Available
Old 07-30-2014, 10:52 AM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Default Speartech GEN-5 LT1 Stand Alone Control System Available
Our GEN-5 LT1 stand alone control system is now available!
The basic package includes the stand alone wiring harness, programmed E92 ECM, and DBW throttle pedal. We also offer a sensor package that includes the special LT1 MAF sensor with 4" aluminum tube and the correct LT1 O2 sensors.
The LT1 crate engine comes from GM with 3 sub-harnesses. Our harness is designed to plug into the sub-harnesses already on the engine. If you're doing a ground up engine build, we also carry the sub-harnesses if needed.
Here's the harness running on our crate engine:
Packages are available for both LT1/6L80 and LT1/Manual Trans applications.
All of our harnesses now include our exclusive high temp, high grade harness covering.
We also have O2 extension harnesses available for the LT1 engine when adding headers, etc.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old 07-30-2014, 04:59 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Impressive!
Are Gen V LT1 crate engines available?
Andrew
Old 07-30-2014, 06:27 PM
Jimbo1367's Avatar
YES.
www.paceperformance.com has them listed.
Old 07-30-2014, 06:35 PM
Speartech's Avatar
I know there have been restrictions at times but I bought the one in the pictures.
Also, there are 2014 trucks getting wrecked with the truck version (5.3 and 6.2) of the LT1.
__________________
www.speartech.com
Old 07-30-2014, 08:02 PM
ls1nova71's Avatar
Man I want one of these!!! Are the truck engines pretty much wired the same? Also, is a speedo and tach able to be run off the PCM?
Old 07-30-2014, 08:24 PM
BOXCHEV's Avatar
YES.
Yikes
$3500 just for core charge lol.
Old 07-30-2014, 08:42 PM
Originally Posted by BOXCHEV
Yikes
I am sure that Chevrolet High Performance will offer these soon enough without a core, much like they do LS3s and other engines.
Andrew
Old 07-30-2014, 09:03 PM
aknovaman's Avatar
External wiring is same. I converted a 2013 v6 Camaro direct injection conversion harness a while back and it is very easy. Tach yes. Speedo not aware as I have not read the lt1 PCM files, yet.
Old 07-31-2014, 09:42 PM
Speartech's Avatar
The truck engines have one less sub-harness and some components are positioned differently, but otherwise they are about the same.
The tach signal is pretty twitchy and will probably need some filtering, we don't have have a speed out signal yet, but it's all early in the development, plenty will be figured out over time.
Or maybe we're just waiting on aknovaman to look at a file and tell us all how it's done.
__________________
www.speartech.com
Quick Reply: Speartech GEN-5 LT1 Stand Alone Control System Available
