Need shallower pan for LQ9
Old Apr 25, 2017 | 08:28 PM
Jackalope's Avatar
Default Need shallower pan for LQ9
i am building a 1930 Model A coupe with a LQ9. Because this came out of an Escalade the original pan could be and is big. Ground clearance is a concern.
My question is can I simply use a Camaro oil pan which gives me an additional 2"+ of ground clearance?
I realize I will need to modify the pick up but short of that is there any reason I couldn't or shouldn't??
The pics don't show it well but there isn't much room between the pan and pavement.
Old Apr 25, 2017 | 09:52 PM
thatoneguybriz's Avatar
I can't really ascertain what type of cross member set up you have, but the corvette "bat-wing" pan is the highest clearance stock LS pan I know of. Its tough to get them to work with stock suspension geometries because of the size of the kick outs. I think guys running Mustang II style suspensions can get them to work, but someone else may want to chime in here and verify that.
I am not sure how well the stock F-body pan will work in your application, but you are correct in noting that you do gain about two inches of clearance off the sump. The Holley Oil pan for LS Swaps in muscle cars is a high clearance version (Part #302-1; https://www.holley.com/products/acce...ns/parts/302-1) which has been used with varying degrees of success. This pan might work for you off the shelf not only because of its shallower rear sump, but also its clearance for drag link steering gear in the front.
Old Apr 26, 2017 | 06:43 AM
Jackalope's Avatar
Thank you for the response. My question is as before. Will a camaro pan work with the LQ9?
please do not worry about cross members, etc. I built the entire thing (frame/suspension/etc) and the only thing of concern is the pavement below. I only need to gain a couple inches of additional ground clearance and that is all.
I simply need to know if there are any reasons the shallower camaro pan won't work engine to engine.
I know most LS components work engine to engine but I am not 100% sure about oil pans hence the inquiry.
I do not want to spend big dollars on an aftermarket pan. I think I can find a camaro pan from someone wanting to upgrade but before I do I want to make sure it'll work.
Thanks again
Old Apr 26, 2017 | 04:50 PM
Sorry for not directly answering your question before. You can bolt an F-Body LS1 pan on the LQ9 providing you have the proper oil pickup tube for the f-body pan. This pickup tube also bolts on as the oil pump is in the same location on the LQ9 as the LS1. I would also grab the F-body windage tray (which is shorter length-wise than the LQ9 I believe), dipstick tube, and the dipstick itself.
If you really want to save money, you can modify your truck-style windage tray by cutting it to a similar length as the F-body tray, modify your existing dipstick tube, remark your dipstick to the F-body full oil level, and shorten your oil pickup tube to fit the shallower pan.
I hope this helps.
Old Apr 26, 2017 | 09:46 PM
Jackalope's Avatar
That, my friend, is what I'm after! Thank you for your reply!
i was actually thinking about just cutting mine down and rewelding. That cast aluminum soaks up contaminates like nobody's business though.
I sincerely appreciate your response. This is very helpful!
thanks again.
Grant
Old Apr 27, 2017 | 06:43 AM
ls1nova71's Avatar
Yes , youll definitely want an F body pan for that car. Be sure to get an oil pick up tube O ring for an F body too since the trucks are a different size, they look the same to the naked eye, but they arent. You can have no oil pressure issues from having the wrong one.
Old Apr 27, 2017 | 07:09 AM
LLLosingit's Avatar
Since you asked the question I'll let you in on a little secret, When GM designed the LS engine they did it much the way they did with the traditional Small block Chevy engine. They made the block dimensions the same for the whole line with very few exceptions. In simple words, The 4.8 5.3 5.7 6.0 6.2 aluminum block or iron block, truck, suv or car are pretty much the same on the exterior so you can swap oil pans/water pumps/ accessory drives/valve covers/intakes (as long as the ports match) front and rear covers/valley covers/ exhaust manifolds. In most cases (not all) even the internal parts are swappable, Oil pumps, crankshaft, Connecting rods, camshafts, timing sets. rocker arms and so on. In 2006 they changed from a 24x to a 58x reluctor wheel that changed the computer needed to run them but again you can change the reluctor wheel to work for your needs.
Old Apr 27, 2017 | 10:08 AM
SikkyMFG's Avatar
This pan may solve your issue for you. Its one of the pans we manufacture here for our 240's. The only thing is it will require you to relocate your oil filter (we offer kits for this additionally). The pan comes with the proper pickup and dip stick
https://www.sikky.com/product/lsx-oil-pan/
Old Apr 28, 2017 | 12:32 PM
ImprovedRacing's Avatar
LS1Tech Sponsor
Here's a link to dimensions and info on several of the factory and Holley pans so you can see what would work best for your setup: http://www.improvedracing.com/tech/L...dimensions.php
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old Apr 28, 2017 | 02:18 PM
bczee's Avatar
This has always been useful
http://paceperformance.com/p-3990-engine-dimensions.html
BC
Old Apr 30, 2017 | 09:24 PM
APillow's Avatar
$200 Done. GM part with all the needed accessories.
https://www.summitracing.com/parts/nal-19212593
Old Apr 30, 2017 | 09:53 PM
ls1nova71's Avatar
That pan is only a bit shallower than the truck pan, so in this car would probably be too deep.
Old Apr 30, 2017 | 11:27 PM
CattleAc's Avatar
Top quote "NO"
Bottom quote "yes"
Stay far away from the GM "muscle car pan" for your hot rod. Hangs way too low...when I did my A-body swap I almost fell prey to the muscle car pan before I did some research. It's just a Hummer H-3 pan marketed to the muscle car crowd...
F-body pan will probably work perfectly in your application.
Old May 1, 2017 | 11:17 AM
Jimbo1367's Avatar
IF GM had any common sense they market the 98-02 -body pan as the muscle car kit and they would dominate the market.
Old May 1, 2017 | 01:20 PM
Floader's Avatar
only problem with the F-body pan is that it hits the cross member on a lot of swap rigs. There are lots of options out there as far as pans go, Google is your friend.
Old May 1, 2017 | 11:06 PM
APillow's Avatar
He has full frame rails and the motor looks high set to me. I bet H3/Hot Rod would fit and it cheap.
If you need a bit shallower the CTS-V pan. Saw one Sunday setup on a LM7 for a Volvo 940 swap. (not sure of price or PN though)
Old May 2, 2017 | 09:20 PM
S10xGN's Avatar
I'm surprised no one has mentioned the late C6 pan, here's a view of one on my Rambler. Notice the rear depth in relation to the bellhousing...
