Yet another '72 short bed build....
Old 01-23-2019, 02:00 PM
408GT's Avatar
Nice build. I have a 62 C-10 that I'm working on now. I'll be following along.
Old 01-23-2019, 03:51 PM
gofastwclass's Avatar
is it redneckery if I do stuff like that but I never get sunburns? how about hickassery?
That's because they don't have sun where you live 75% of the year. Haha!
Old 01-23-2019, 04:39 PM
LS1 TJ's Avatar
Kind of chilly up in central MN today. 17 degrees. Tomorrow maybe 5 degrees and 30 mph NW winds so what else is there anything to do but build hot rods?
So an my 68 C10 build I learned a few things. LS1/T56.
Get the engine down low in the chassis. I used ECE mounts engine and trans mount. Wouldn't do that again. Maybe if I was using an auto but the ECE engine mounts make the engine angle a bit extreme with a T56. They may work well for an auto.
Also if you are into fabbing up engine mounts the LS could go back a solid 2" compared to the ECE engine mounts. May need a high hump trans cover.
Old 01-24-2019, 10:48 PM
ls1nova71's Avatar
This whole truck is made up of parts I've gathered over the years. Dont think the truck this rear end came out of had rear brakes for a while....
After some paint the frame is looking pretty good.
So now it can begin going back together.
Old 01-24-2019, 10:54 PM
ls1nova71's Avatar
dont forget the LCA mod while they're off!
I thought about doing that, but at the time I was in a big hurry so didn't mess with it. I'm thinking when its all done I will get another set of lower control arms and actually move the lower ball joint forward a bit. Not my idea, but I have seen it done before and should work out pretty well, we'll see if it actually gets done though. LOL
Old 01-25-2019, 09:17 AM
BlueMaxCougar's Avatar
Great start on the new project. Can you explain the LCA mod? I've been looking at trucks lately and a long bed C-10 is on my list.
Old 01-25-2019, 01:49 PM
ls1nova71's Avatar
It involves refilling the lower cross shaft to put more caster in the front end. Look up Truckdoug's thread Pearl, the inexpensive square body build, he shows it in detail.
Old 01-25-2019, 03:04 PM
truckdoug's Avatar
how much does it run you to have a frame media blasted like that?
working on this g body...they sprang for the dealer undercoat ....ugh its like someone sprayed hot tar on everything they could see from underneath ...so gross
Old 01-25-2019, 04:13 PM
LS1 TJ's Avatar
On my TJ LS project which is a full frame it cost $300 for the sand blasting. Local sand blasting shop is time and material. Because I wasn't in a big hurry it was fill in work and they did it when the humidity was low. Having said that I waited about a week. And the cool part was that they loaded it on a fork lift and took it over to the powder coat shop. No flash rust.
Powder coat loves a sand blasted surface. If you are going that route knock off the sharp edges on the frame. Powder fails when it cracks and allows moisture in.
Old 01-26-2019, 09:26 AM
Thanks. Will check it out.
Old 01-26-2019, 10:18 AM
Jimbo1367's Avatar
Ls1nova71,
what size garage do you work in at home? What spray guns do you use, primer and color? Oh yeah, Clear coat and what size tips too?
You make doing all these bad *** swap projects look so easy. You knock them out so effortlessly.
Thanks,
Jim
Old 01-26-2019, 05:09 PM
  #32
I know because I've been there, his garage is about the size of a large shoe box. The term 10 pounds of stuff in a 5 pound box is a good description. Ironically we both have about the same space laid out differently... and it sucks to work in - but it gets done with determination.
Old 01-28-2019, 03:58 AM
  #33
ls1nova71's Avatar
Ls1nova71,
Thanks,
Jim
Yeah, Bry's right, it's small. It's a detached 2 car, probably 20x24 or so, it's better than nothing but definitely could use to be bigger. The paint guns I use are really old DeVilbiss guns, but I do have a couple of cheap Harbor Freight gravity feed guns that work surprisingly well for about one vehicle.
Old 01-28-2019, 04:46 AM
  #34
Jimbo1367's Avatar
Thanks. I always thought DeVilbiss guns weren't any good. Good to know they provide good results.
thanks,
Jim
Old 01-28-2019, 06:22 AM
  #35
I used to work with a guy who used HF guns exclusively and got decent results. A bit more orange peel than I prefer and nothing show quality but no major defects either. His work was actually very motivating when you looked at the results and space he had to work in.
If you see one of ls1nova71's cars up close and in person you wouldn't think it was painted (or even built) in a garage at a house.
Old 01-28-2019, 12:22 PM
  #36
daaaanz67's Avatar
Nova nice build . I’ve seen some of your work especially that in cab tank baffle mod. Your work is top notch. Bought a cruise lever from you years ago still works great knock on wood LOL. Is this build on the 67-72 thread. Going to keep an eye on this.
Old 01-29-2019, 03:42 AM
  #37
ls1nova71's Avatar
Since I started this build in the spring, by the time I got to putting the frame together it was warming up. I had these painted trailing arms sitting on my deck for an hour or so before I went to get them and damn near burned myself! I miss summer....
Old 01-29-2019, 03:43 AM
  #38
ls1nova71's Avatar
Cant upload pics again????
Old 01-29-2019, 04:39 AM
  #39
I was going to ask if you were losing more of your mind...
Old 01-29-2019, 05:16 AM
  #40
ls1nova71's Avatar
Well, yeah, I'm sure, but still cant upload any pics....
