I’ll try and let the pics explain it.. I find this clean 4 cyl. Coupe with oversized wheels/tires, real tacky window tint and red velvetine interior on CL in the Central Valley of Ca.
Reason: Update title
Was thinking IRS swap at one point. This unit is from a ‘15 Mustang V6 base model it’s 8.8 as well, from a local wrecker nearby. The price was maybe too good to let it pass by.
In and out came the left header for steering shaft configuration and clearance issues, hours and hours spent here. Ended up with a Flaming River low profile lower steering shaft to clear the Hedman mid length headers. Eventually the 2.5” ball sockets were cut off the headers in favor of 3” V-band flanges to match the collector and exhaust tubing size. Ball socket seemed restrictive and not too impressed with nut and bolt flanges that secure them, they bend, leak and just plain look bad.
Discovered swapping AJE motor mounts left to right with points going forward moved the engine back over 3/4” and this worked perfect for the transmission mount as it lined up perfect on the QA1 crossmember used. The points on the motor mounts had to be cut off if I were ever going to retro fit AC on this car and just looked cleaner with out them. An extra hole was drilled into both mounts so 4 10mm bolts could be used vs 3. It might help with using an aluminum block, maybe not.
Engine build. : a LH6 gen4 5.3, it came with 243 heads.
Block bored .123” ( that’s roughly an 1/8 inch lol.) and torque plate honed to 3.903”
Wiseco Pro-Tru 4cc heavy domed pistons with Included Wiseco file fit rings.
Heavy Gen4 bushed Rods, polished 3.622 stroke 58x LH6 crankshaft. Bob weights were 1800 and kinda heavier than I would have ever liked.
CamMotion 227-232 113+4 .610 lift cam (Titan4) Powell 11/32 .080 wall pushrods, stock rocker arms with Smith Bros. Bronze trunion upgrades, .650 dual spring kit, Cadillac race lifters, JP single roller adjustable timing set, Meling 10296 oil pump, Corvette C6 oil pan, pick up and tray, SFI damper pinned to the crank , Jegs SFI 168 flexplat for LS crank and TH350-400.
Heads are 243s CNC’d by Katech, stock valves and milled .004, Holley valve covers, MSD reman Street-fire coils, Fitech sheet metal intake and included 92mmTB, 36lb injectors.
11.63:1 SCR, the goal here is 440rwhp
Griffin Foxbody/ LS conversion radiator off eBay for $300 Lincoln Mark VIII 2 speed light weight fan “blows” the 3.0 Taurus fan away. Hose outlets on this rad. are 1-1/4 and 1-5/16? The fbody hoses work perfect without adaptors.
