More wires than sensors. Need help
I am trying to install the harness and am coming up with more wires than sensors. (First two pics)
It appears that I have missing sensors around the throttle body. (Second Pic)
I have also found 3 sensors that I cannot find a connections for. (Third, forth and last pic)
Id sure like to know what to do with these extra wires and if the sensors are needed.
Is it normal to have the a/c compressor lead in the harness? Mine is. I suppose the ecm controls it?
All help is appreciated.
sawzall wielding director
Pic 1> the 4 pin is the idle air control. Need a side view or wire colors to ID the rest
Pic2 middle one is the TPS sensor connector. I can`t tell on the other 2, how bout a side view or the wire colors?
Pic3 Your missing the idle air control and the bottom is the TPS sensor
pic 4 I`m sufficiently confused, what year is the motor?
pic5 Looks like an EVAP purge solenoid, but that is normally mounted on the top of the intake right behind the TB
pic 6 This is the oil pressure sender.
To the OP, you need to post a pic of the whole Harness and put a number next to each Connector, and we can give you the names easier.
correct. Cam position sensor, oil pressure sensor, and MAP sensor. if they are all grouped together, then thats what they are. the 3 pin flat connectors are keyed the same, so you'll have to match up wire colors to make any headway. What year harness is this? I can post up the PCM pinouts/schematics If i have them.
I appreciate the feedback. The motor and harness are supposed to a 2000 model, although the intake and fuel rails have been replaced.
The TPS, coolant and temperature sensors are already connected. If the cam sensor is at the back of the of the block where a distributor would normally sit, it is connected as well. If the crank sensor is at the back of the intake, connected via its own pigtail and female connector, it is connected as well.
I can not get any of the loose connectors to fit into the EGR (pic 4), EVAP (pic 5) or the oil sender (pic 6). Does the ecm need these?
Am I missing the MAF, Idle air control and AIT sensors?
I've read that the a/c system has sensors. Could any of the loose ones be a/c?
Could one of the loose connectors be for the speed sensor in the transmission? The harness has the big round plug, but nothing that will reach the speed sensor. The harness originally had a 6 speed and I had it converted to a 4L60e.
Again, I appreciate the help.
Just looked through my schematics and this is what I found. This is just what they could possibly be.Just match up the wire colors, and you should be in business.
4 Pin Connectors
Lt Grn/Wht, Lt Grn/blk, Lt blu/Blk, Lt blu/wht
Idle Air Control Valve
3 Pin connectors
Wire colors - blk/wht, pnk, yel
MAF connector
Lt grn, yel/blk, dk blu/wht
Crank Pos sensor (right rear of engine, behind starter)
brn/wht, pnk/blk, red
Camshaft POS sensor (Top rear of engine)
org/blk, lt grn, gray
MAP sensor (rear of intake manifold)
dk blu, blk, gray
Throttle Pos sensor (on TB)
Red/blk, PPL, Gray
A/C refrigerant pressure sensor
2 Wire Connectors
Dk grn, blk
A/C Compressor Clutch
Tan, PPl
IAT Sensor
blk, yel
Coolant Temp sensor (Drivers side cyl head)
Brn, blk/wht
Oil Level Sensor (Pass side of oil Pan)
Red, Blk
Secondary AIR injection Pump
Pnk/Blk, Org
Secondary AIR Injection Bypass Valve
Pnk, Wht
EVAP Canister Vent Solenoid
Pnk, DK Grn/Wht
EVAP Purge Solenoid (left side of intake Manifold)
PPL/wht, Lt Grn/Blk
Vehicle Speed Sensor
4 Pin Connectors
3 Pin connectors
MAF connector
dk blu, blk, gray
Red/blk, PPL, Gray
2 Wire Connectors
Dk grn, blk
Tan, PPl
IAT Sensor
blk, yel
Brn, blk/wht
Red, Blk
Pnk/Blk, Org
Pnk, Wht
Pnk, DK Grn/Wht
PPL/wht, Lt Grn/Blk
Finally have a closure on the loose sensor leads. I appreciate the help.
Need to lengthen the VSS wires. Way too short. Can I use butt connectors and same size wiring? Also would like to position the ECM on the driver's side but need to lengthen the cam sensor wires. Can I lengthen those with butt connectors as well?
I wouldn't use butt connectors. They allow moisture to contact the wire and it will start to corrode. It starts to corrode UNDER the sheathing, so if you have an electrical problem, its going to be hell to try and trouble shoot...Soldering all the way.
