LQ4 in a 1971 Nova
Those belts look great. What are they from? I definitely spent more than I needed to on the Morris belts, but it took some guesswork out of it. I think having that one in the center is pretty cool. That'll come in handy, especially as the kids get older. With 3 you are definitely going to need it.
I honestly don't know how much load that top anchor needs to carry. Thinking about how the stock lower anchors are done at the floorpan, there is some reinforcement in the immediate vicinity of the threaded hole, but it's still relatively thin sheet metal around it. I've never heard of the sheet metal pulling out or anything but not sure how closely people have actually looked at these areas after a serious accident. You could possibly span the package tray with a square tube underneath and then tie into that. I wish I had the time and budget to test this stuff. I have a strong interest in improving safety with these old cars.
My belts came out of a Neon, I think. I had to fab brackets for the receivers, since our seats sit so high relative to new ones*. The install was otherwise fairly straightforward.
*side note: one of my favorite things is watching the boys' heads fly up in my rearview whenever I hit a decent bump. The back seat is ridiculously springy.
Be careful posting that IHS 50th anniversary crash test comparison. All kinds of folks will pop out of the woodwork talking about how much safer these "real steel" cars are than the new stuff and how that '59 in the video is just a bad example because it was an x-frame car. Uh huh sure.
Lol!!
For reference, here's the before (top) and after (bottom). It's a little hard to see the angle it was at before, but trust that it's much better now.
Before
After
And the clearancing I had to do. Firewall is to the left.
I don't use the line lock that often, but the boys like to push it and do burnouts.
And I have a couple summer projects lined up, one of which will require a cherry picker and engine stand.
When I built the engine, I elected to go with Mahle pistons with 4cc LS3 reliefs. Those required 6.125" rods, so I bought a set of scat I beams. What I SHOULD HAVE done but didn't was just gone with a 408 from the get-go. So I'm exploring a new rotating assembly - likely scat 4" crank and Mahle LS3 pistons with lower compression height. I've also reached out to LG to see how the G6X3 would respond to more cubes. I'm not going to be building anything for a little while.
Onto my radiator. I elected to go with a larger 31x19" radiator to combat the 110+°F (45+°C) temps here in Phoenix. The Afco OEM replacement performed admirably, but it wasn't up to the task of keeping cool when the Vintage Air came on (which is literally always in the summer). The OEM radiator has a core size of 17 1/4" x 20 5/8", for a total area of ~357 in². The new Griffin, on the other hand, has a core size of 19"x26", for a total area of 494 in². This is a 37% increase in surface area, which will certainly help keep this thing cool. I paired this to a junkyard Volvo fan, which is easily removed from the shroud.
To make my new shroud, I picked up some 5052 sheet aluminum (.050", I believe). I was able to make a shroud fairly easily; I unfortunately didn't take photos, but trust that I did my work with only an angle grinder, some clamps and a hammer. This guy's got a pretty informative post if you're looking to do something similar.
You may recall that I completely sealed the underside of my fiberglass hood. That actually led to problems with the radiator cap, interfered with closing it fully. Surprisingly, I had plenty of room to my alternator. While I was in there I elected to get all frojoey and drop the radiator about 2". Not only did this require some cutting and welding on the radiator support, it also necessitated a new upper radiator mount. I actually had to flatten out the lower radiator mount by cutting the lip in order to fit this particular unit. You can see two seals at the top of the radiator - the radiator core has rails on top and bottom, which I covered with an extra trunk seal I had laying around. I bent a piece of 14ga sheet into the top mount, which effectively hugs the radiator against the support to keep it in place. I also hit the aft of the support with some rubber insulation strips to keep it sealed.
I still need to clean it all up and paint, but it is essentially done. I'll try to get some more photos as I bolt the front trim back in.
Great job with the big radiator install! Do you have a trinary switch wired in so you get fan high speed whenever the AC is running? Why did you swap to the Volvo fan over the Taurus you had before?
I have a trinary switch, but I'm not completely sure it grounds the high-speed circuit when AC kicks on; in fact, I'm not sure the ECM triggers high-speed, either. I wired in a manual switch to ground for high speed trigger last summer, but plan to investigate further.
My next move is to look at the intake. I've found these silicone U hoses that might work - leg spacing is 6" center-to-center, and the legs are 4" to the center line of the bend. I'd build a fiberglass air box and seal to the underside of the hood, as shown in my photo below. I'd likely use an oval cone filter, though a panel filter has crossed my mind - it would seal between the box and hood, but would have no other retaining method, which is less than desirable. I simply need to take some measurements next time I'm in the garage.
Personally I prefer a panel style filter(s) for that arrangement. because you just don't have enough room to fit an adequate size cone filter and it lends itself to the rectangular opening at the top. One of my Internet friends built this really cool setup for his sprint car based on the K&N Lola spec filter. Here is an in progress photo of his filter housing. The filter is K&N 33-2495 and it's 20-15/16 x 16 x 5/8. I hate the look of a 180 degree u-bend. Instead I would make the box come forward over and in front of the throttle body and just use a 90 degree bend going up to the box. But of course that wouldn't accommodate the MAF. The only acceptable solution is ITBs.
Also: if any of you Nova guys know exactly how the headlight bucket springs install onto the buckets, I'd love to see photos. All the threads on Steve's have been hosed by the Photobucket fiasco.
