LQ4 in a 1971 Nova
Old Aug 2, 2013 | 03:18 PM
  #361
speedtigger's Avatar
Old School Heavy
Originally Posted by hookemdevils22
I twisted the driveshaft. Which is bad, but also pretty awesome?
LOL. Quote of the day.
Old Aug 2, 2013 | 07:45 PM
  #362
-TheBandit-'s Avatar
Luckily a new pinion bearing isn't to hard to fix if there's no gear damage. I still feel like the root cause of the vibration was else where, perhaps it has more to do with the twisted shaft. You must have been putting the hurt on that thing.
Old Aug 2, 2013 | 08:57 PM
  #363
hookemdevils22's Avatar
Well, you saw the gears, so I'm pretty sure they're ok. I plan to replace the bearing, yoke, etc. I heard the yoke can cause vibration, so I'm replacing it since I'm in there.
In other news, my fan quit working today, and I very nearly burned her to the ground. Luckily I found the problem quickly - the dumbass who did the wiring used butt connectors instead of soldering like he should have done (I refuse to show pics because I'm so embarrassed). Let this be a lesson, and remember - if I can somehow do this and make it work (seeing how much I've had to go back and redo things), anyone can. It's really a shame to see Clint's excellent work then deal with my crap. But at least I'm (slowly) working out the kinks.
Old Aug 2, 2013 | 11:28 PM
  #364
futureuser's Avatar
That set up looks wonderful.
Old Sep 23, 2013 | 05:26 PM
  #365
Turtle Bite's Avatar
The wheels look great. Sounds like a near miss on the fan, cant say I havent done the same so you wont get any judgement from me.
Based on the driving you have done so far, does it look like the front wheels are clearing with that offset/ adapter? Do you know how far you are lowered from stock in the front? Standard inner fenders? Where did you get the adapters from, and how is the quality?
I need to figure out what to do with my car for wheels, and I am thinking of going with wheel adapters to get a more affordable wheel in a style I like. There a a couple of TSWs that are close, and copying sizes that you have already tested would save me alot of time and money.
Just wondering, but have any of the shops checked your rear end with an aligment bar and pucks? I regeared a Dana 60 once that came out of a nice clean van, and was amazed how far out of alignment the housing ends were from the factory. I cant see how that would cause youre vibration issue, it usually kills wheel bearings, wheel seals, and carrier bearings. Just grasping at straws since it seems like you have hit all the common problems already.
Old Sep 24, 2013 | 11:38 AM
  #366
They clear great. My camber is set to zero, which I'm not happy about, but I've hammered on her pretty hard with zero rubbing.
I'd guess 2". I'm pretty sure the apex of the outer fender wheel cutout is about 23" from the pavement.
Standard inner fenders? Yes
They came with a set of 17" Ford wheels I bought. Not sure the brand. They're excellent, though I milled the rears down to .500".
TSW makes some great wheels. And there are so many more options if you go with a Ford bolt pattern. Though drilling the rear axles was a pain in the ***.
Actually, no. I haven't gotten too far with it due to various other things coming up. That's a great idea though.
Did a car show this weekend. So glad it's finally cooling off. Vibes come in bad about 65, nearly go away at 70-75, then come back with a vengeance above that.
Old Sep 25, 2013 | 01:07 PM
  #367
Thanks for the info. I am getting sold on going to the ford bolt pattern.
So I take it you got a replacement driveshaft? Vibration is the same as before?
Old Sep 25, 2013 | 01:28 PM
  #368
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
This has been a really cool read. Love the car!
-Garrett
Old Sep 25, 2013 | 03:26 PM
  #369
Nope, driveshaft has not been replaced. I should probably do it before GoodGuys in November though...
Garrett, thanks bud. I'm head over heels in love with the thing, vibes notwithstanding.
Old Sep 25, 2013 | 03:39 PM
  #370
You haven't replaced your twisted driveshaft? Didn't you just get through rebuilding the rearend? Don't put your fresh bearings and seals against that abuse any more than you have to.
Old Sep 25, 2013 | 03:41 PM
  #371
I put new outer wheel bearings and seals on, I wouldn't say I really rebuilt it. I'm honestly waiting for my house to sell to decide what I'm doing. The 4L80e might be coming out for a T56, at which point a new DS would be required anyway.
Old Sep 25, 2013 | 04:06 PM
  #372
bczee's Avatar
Hook.. on the front.. so.. the 18x8 with 5"bs is what it came out to ? (w/245x40x18). I tried my front wheel/tire from the chevelle on (17x8 w/4.5bs).. seem like another 1/2" would clear well..
On the rear.. how much space do you have between the inner fender and the tire.. ? could you measure how much rim is on the outside from the Hub ? (yeah. I know most people measure inner offset, but this way I know how much i have to work with outside and then work inward). I tried the chevelle front on the rear also.. had less than 1/2" between the inner/lip and tire.. so I am thinking 8" rim with 5" or 5 1/4" bs would work.. then add the extra 1" on the inside of the rim.
going to post the pictures of the trial on my build thread.. don't want to junk up your build thead with my junk ! LOL
thanks..
BC
Old Sep 26, 2013 | 03:18 PM
  #373
BC, just answered your questions on your thread.
Old Sep 26, 2013 | 03:48 PM
  #374
bczee's Avatar
thanks..
Old Nov 8, 2013 | 08:54 PM
  #375
tsnow678's Avatar
Do you have the parking brakes working on your rear disc swap? If so, what did you do for cables since the ends are different from stock?
Old Nov 9, 2013 | 10:24 AM
  #376
I do not... bczee has a good write-up on how he made it work. I have a neon center console and plan to install the floor-mount parking brake lever, which will likely require some creative fabbing to install.
I'll be doing it soon, along with a huge drivetrain change. Stay tuned...
Old Nov 9, 2013 | 12:03 PM
  #377
1989GTA's Avatar
On my Skylark I I have 17" x 8" wheels on the front and 17" x 9.5" on the rear. On the rear I needed 6 3/8" backspacing with 285/40ZR17 tires. On the front with 5.0" of backspacing and 255/45ZR17 tires I had rubbing. I needed at least 5.25" of backspacing for that size of tire. Maybe more. I installed 245/45ZR17 tires on the front and the rubbing is down to almost nothing but there is some in certain situations.
Old Nov 12, 2013 | 02:37 PM
  #378
Small update. So this happened last night...
Revisiting a question I asked a few months ago, it appears that I have only a couple wiring bits to take care of to install a T56. bczee laid it out pretty well here (my inputs in bold):
1) VSS - I don't run a VSS to the PCM in my swap and have not had any issue of low idle or dying on stopping.. but the PCM does like to know when your not moving. My problem is that I have a Viper T56 whcih uses a different VSS and signal.
The F-body and 99-02 truck PCMs use the same pins (connector C2, pins 20 and 21) for VSS. The 4L80e has input and output speed sensors (output pins are C2 22/23), so depending on where the VSS is taken on the T56 (input or output), I can plug into either. I'm pretty sure this won't be difficult. This seems to be the only PCM input necessary.
2) Reverse Light Switch - Helpfull at night. I didn't run with one for a few years. Finally got around to it. Most will get out of the way anyway..LOL
I'm guessing that this is wired to a switch on the trans a la most manuals I know. I shouldn't have a problem here. No input to PCM.
3) Reverse Lockout - May have said they just slam it over, other have removed it. I have a Line Lock switch for to activate mine.
bc, care to comment on how you did this? Just use a momentary switch? Again, no PCM input.
4) CAG / Skip shift - The only one that is really useless, is this one.
This can be just disconnected or omitted at the trans with no issues?
So I've ordered a third pedal and MC bracket. 80 should be out this week, expecting the T56/clutch/Tick master to arrive before turkey day.
Old Nov 12, 2013 | 03:30 PM
  #379
tsnow678's Avatar
You will love the T56!!
Old Nov 12, 2013 | 04:19 PM
  #380
garrysturbo's Avatar
Hey sorry about some of ur issues that you've been having but ur new T56 will be fun & keep up the good work .
Thanks Garry
